Solo Performance
Old 08-07-2010, 10:18 PM   #1
SSmoothie
SSmoothie's Avatar
Drives: 2010 Camaro 2SS/RS 6SP Blk/Blk
Pedders Xa coilover questions help
I've search so don't give me the search button, anyway I'm confused in the directions of where I measurement on the coilover to get my 1.5 ride height. I tighten the seats to the coil is snug, mounted them on the car do I adjust with no wheels on or do install wheels and take them of an on until I get my right height I want? I on the front as of now.
SSmoothie is offline   Reply With Quote
Old 08-07-2010, 10:20 PM   #2
SSmoothie
SSmoothie's Avatar
Oh, it talks about preliminary height adjustment but I can't understand were to get that measurement.
TIA
Old 08-07-2010, 11:12 PM   #3
Camaro427
Drives: 2010 SS2 Camaro
Camaro427 is offline   Reply With Quote
Old 08-08-2010, 10:13 AM   #4
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
You can find how to take your measurements here
http://g8modz.com/frontxa.htm
This post I made will help you adjust the height after installation.
http://www.camaro5.com/forums/showpo...21&postcount=5
Jaysin is offline   Reply With Quote
Old 08-08-2010, 12:52 PM   #5
SSmoothie
SSmoothie's Avatar
Thanks Jaysin, I did see you post on adjusting, I just wasn't sure on how to get my drop of 2 inches front and 1.5 in back but you and Seddon have giving me enough info to figure it out.
Thanks
Clay
Old 08-08-2010, 05:19 PM   #6
g-townmach
I FARTED
g-townmach's Avatar
Drives: 2010 2SS/RS
The way I did it was just guess at where to put the collars when I initially installed mine. Then put the wheels on and set the car back on the ground and looked at how much it needed to go up or down. Then just pulled the wheels back off and made the adjustments. This was on KW V1's but its the same concept for your "peddlers."
g-townmach is offline   Reply With Quote
Old 08-08-2010, 06:01 PM   #7
SSmoothie
SSmoothie's Avatar
Seddon gave me his measurements between the upper and lower locknuts.
Anyway now I trying to figure out why I have a gap on the upper strut covers. I installed it with the cup down (as in the pic below) and it hits the washer below, so the top cover does not sit down all the way. If I turn them over they fit.
Old 08-08-2010, 09:11 PM   #8
Jaysin
Jaysin's Avatar
Remember that the instructions I gave you were for a G8. I haven't dug into the Camaro yet.
Old 08-08-2010, 09:16 PM   #9
Camaro427
Pedders has a link with a number of instruction pages.
Old 08-08-2010, 09:41 PM   #10
SSmoothie
SSmoothie's Avatar
Yes I have them, but some things are not clear, have you done the install?
Old 08-08-2010, 10:10 PM   #11
Camaro427
Yes I have.
Old 08-09-2010, 12:11 AM   #12
SSmoothie
SSmoothie's Avatar
Ok then in the first pic I've torque this nut down.
Then the top cover came stock like this but there is a small gap now underneath it.
But It fits fine if I turn the cap over, am I missing something because in the directions it does not take about the cap being turn over.
TIA
Old 08-09-2010, 01:45 AM   #13
Camaro427
You need to have the upper plate so the center section is down. That is how GM intended it to be.
Old 08-09-2010, 02:54 AM   #14
SSmoothie
SSmoothie's Avatar
So I'm suppose to have that gap between the top cap and the housing?
ETMC you one stop shop for PEDDERS SUSPENSION XA COILOVER SAlE and MUCH MUCH MORE! east TX Muscle cars Suspension / Chassis / Brakes 2 09-17-2009 03:42 PM
Pedders Xa Coilover Preorder Special Rob@WretchedMS Suspension / Chassis / Brakes 28 09-16-2009 06:39 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 06:20 PM
