Cold Air Inductions
Old 11-24-2008, 03:08 AM   #1
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
Emissions?
Im getting some LT's and I want to tune out the (and remove) EGR/AIR system, and tune out the rear O2 sensors. All OR requires for emissions is the OBD scan. Will I pass? heres what my emissions cert looks like
OBD results:
Misfire: ready
fuel system: ready
comprehensive: ready
catalyst: ready
DLC: pass
Smoke: pass
Noise: pass
OBD sensor stat:
catalyst: unsupported
evaporative: ready
2nd Air:ready
AC: Unsupported
COMM: Pass
O2 sensor: ready
02 heater: ready
EGR: ready
thanx
TFord is offline   Reply With Quote
Old 11-24-2008, 12:16 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Well, I know that there are tests that are run over different driving conditions and parameters (i.e. starting a a stop and increasing speed 1/2 throttle to 50 MPH and then coasting to like 30 MPH or something a few times) that the PCM must check as okay. I believe of all the tests the PCM runs and tests, three or five have to have been run or passed. I don't know about your unsupported results though... A smog tech' should be able to tell you though.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 11-24-2008, 01:53 PM   #3
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
when I went there all they did was have me park my car, hook up the scanner...it took a couple of minutes and they were like, thats 12 dollars?
Old 11-24-2008, 03:45 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
a lot of places are converting over to no longer doing a sniffer test, just hooking up to the diagnostic port and seeing if the engine is showing any abnormal emissions.
which if you tune out the post o2 sensors, you shouldn't have a problem. tho if they do a visual inspection, they might ping you on having no cats. unless you are going to spend the money to do a high flow cat setup that will need to be fabbed into the y-pipe
I piss excellence
and fart awesomeness
Old 11-24-2008, 04:33 PM   #5
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
I plan on getting high flow cats...but what about the egr/air? can I remove/delete those so I can get race headers?
Old 11-24-2008, 05:37 PM   #6
CamaroSpike23
Truth Enforcer
of course. you said you are getting longtubes, are you planning true duals or an ORY? and where are you getting them from?
reason I ask, is depending on which you are doing and where you get them from, will depend on your options for running the cats.
I piss excellence
Old 11-24-2008, 10:19 PM   #7
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
either slp, the tsp setup, or kooks/qtp if I can find em on sale (ory)
...remove/delete egr, and pass the obd scan?
Old 11-25-2008, 09:50 AM   #8
CamaroSpike23
Truth Enforcer
what catback are you running or planning on running? jw.
hit up my buddy shon at www.herronperformance.com tell him Greg Norris sent you.
Ceramic coated Pacesetter longtubes with ORY for roughly $500.00 shipped.
then you can just remove the AIR and EGR stuff and get a tune for the rear o2 sensors and the EGR/AIR stuff to pass emissions testing. and if I remember right, Shon does LS1 mail order tunes as well for about $165.00
I piss excellence
Old 11-25-2008, 01:22 PM   #9
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Im planing on going with Magnaflow or GMMG
How many people will E-85 their new camaro? Speed74SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 01-03-2011 02:16 PM
UPDATE: Carmakers May Face New Emissions Standards bigralph 5th Gen Camaro SS LS LT General Discussions 14 11-16-2008 02:16 PM
Emissions TFord 4th Generation Camaros 1 09-07-2008 02:29 PM
"World’s first renewable gasoline" Scotsman General Automotive + Other Cars Discussion 57 07-14-2008 10:55 AM
CAFE 75 mpg in 2030 Scotsman General Automotive + Other Cars Discussion 45 04-21-2008 02:17 AM
