JDP Motorsports
Old 08-09-2010, 06:06 PM   #1
mark_p
Drives: 2010 2SSRS m6
2010 SSRS with LS7 442 stroker ((((NEW PRICE 38,000.00)))) OVER 70,000 INVESTED
11,000 miles
mods
TRUE LS7 442 Ci stroker professionally built (Scoggin Dickey)
All forged rotating assembly (best I could buy) 11:15 compression
Ported heads (vengence racing)
new valves, triple springs etc.
102 mm intake
102 mm throttle body
65 lb injectors
Comp cam
roller rockers
etc etc etc. (complete list to the person who is serious)
Fidanza ceramic twin clutch
hendrix 300m axles (1000HP)
4:10 gears
hurst shifter
eiback springs
sway bars
trailing arms
drive shaft loop
etc.
ground effects
305 drag radials
borla exhaust
full electronic cut-outs
etc.
Professionally installed wet ZEX nitrous system with stand alone fuel cell with built in walbro 255 pump and aeromotive regulator. electonic bottle opener, purge,blanket, progressive controller etc.
This car has 30,000 invested on top of the car. All work done in the last 4,000 miles. Runs perfect.... car is a absolute BEAST.... One of the fastest in the country.. 662-801-9249
70,000 invested.....First 38,000 gets it.
mark_p is offline   Reply With Quote
Old 08-09-2010, 06:22 PM   #2
Bad azz
Old 08-10-2010, 11:42 AM   #3
Bushidopupil
Bushidopupil's Avatar
Drives: 2011 CTS-V Coupe
Dyno or Track numbers?
Bushidopupil is offline   Reply With Quote
Old 08-10-2010, 03:31 PM   #4
383ss
Drives: 1985 IROC, 2011 Camaro
wow, thats a STEAL
the smartest person on Camaro5! Thanks for enlightening us!
Originally Posted by hsdguru View Post
31000 for ss1 no options and who in the hell would buy a SS1 V6 for kids SS1 for girls LS3 the only way to go G8 Gxp 200lbs more my bad so lets think here 200lb more 27 less hp so 5 tenths slower now 373 gear now mabe 3tenths slower 4 door car sad so so sad
383ss is offline   Reply With Quote
Old 08-11-2010, 05:09 PM   #5
stepuptata
stepuptata's Avatar
Drives: 2010 SS and 1999 SS Vortech Blown
wow..i luv it..g luck!
stepuptata is offline   Reply With Quote
Old 08-12-2010, 08:08 AM   #6
mark_p
LS7 Aluminum Block (wet sump)
Scat Crank ( they are the only ones that had a crank for this combo already built)
Wiseco pistons 11.15:1 (with their new wear technology) 2618 T6 material (and yes they are very quiet even on start up with Wisecos new technology)
Forged H-Beam Rods
Comp Cams Cam (238-254 with 610 lifts at 110LSA) This is with 1.7 rockers
Rocker trunnion upgrades to full roller
Hardened push rods
Upgraded timing gear and chain
New lifters
New trays
All engine and head bolts were replaced with ARP studs
Heads were sent to Vengeance racing for a full CNC port. New seats and new stainless steel valves with better valve angles
Comp cam 921 springs with tool steel retainers. (seen the titanium break before)
High flow oil pump (hold about 10psi over stock.
Fast 102 mm intake
Nickey Williams 102mm drive by wire throttle body
Fast 65 Lb injectors
Vararam 102MM intake (custom made by Vararam for this large engine)
Catch cans
Exhaust
Kooks long tube headers (1.875” dia) with 3” collectors
Full exhaust
Two electronic cut-outs (sounds like you unleashed a full blown drag car when they are open)
NO CATS
Borla Mufflers
Drive Train
Fidanza twin ceramic clutch (1000 Hp clutch)
Hurst Shifter
Richmond 4:10 gears (quiet as stock)
Hendrix 1000 HP 300M axles
Drive shaft safety loop
Upgraded drive shaft studs (ARP)
Suspension and tires
Treated and stiffened sway bars
BMR Trailing arms (no more wheel hop)
1.5” drop Eiback springs
New bushings
Nitto 305 Drag radials
Line lock on front wheels
Power adder
Zex full race nitrous kit (this is the good kit with the LARGE solinoids)
Purge kit
Bottle heater
Remote electric bottle opener
Electronic WOT switch
Stand alone fuel Cell from nitrous express with submerged fuel pump and Aeromotive fully adjustable regulator (1 gallon)
Engine would safely handle a 200 shot all day long. I have not ran over a 100 shot in it at this time. (can’t get any traction as it is)
Old 08-12-2010, 02:32 PM   #7
stand-al0ne
Rev Couture
stand-al0ne's Avatar
Drives: 2010 LS Camaro & 2013 Rav4 Ltd
damn I wish I had monayy
EBC Brakes| DOT 4|Bigworm| SickSpeed| BMR | IPF | Vararam| MRT |MGW | Nitto | Rx |
Iggee |ZL-1 Sways| Hurst | Apex Racing|Past: Srt-4| 6.0L GTO- RIP | '98 Integra
stand-al0ne is offline   Reply With Quote
Old 08-14-2010, 12:18 PM   #8
Legend
Hello!
Legend's Avatar
Drives: 2008 JSB Z06!
Bad ass Camaro!!
Free bump for an awesome Camaro!
Legend is offline   Reply With Quote
Old 08-15-2010, 10:48 AM   #9
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Sick Bro!
Old 09-02-2010, 10:43 PM   #10
Napper
Napper's Avatar
Drives: 2SS RS A6/ CTS-V A6 LSA
Wanna trade for a 2010 CTS-V
i would need a few thousand......4k miles...triple black brand new garaged
has but cold air intake and header back with stock mufflers...
still will run 12 flats ....auto sedan!
think about it.
10 2SS(7Psi)/10 CTS-V(9Psi)
L99, ADM RACE CAI, TVS 2300,LG- Headers and X pipe ,catless 3 inch back w/Magnaflows , Ngk plugs,Msd wires,180 stat,Springs ( lowered 1"- looks solidly correct)Sways and endlinks,BMR trailing arms, Slotted rotors and Hawk HPS ,tuned ,Black out bowtie and custom (black)"SS" on sides /midnight rims (8psi)
2010 Raven (triple black.)CTS-v , crank pulley, Bubb CAI , AR Headers, custom catlessback. magnaflows. tune ( 9psi)
former LS7, LS2 and LS1 owner.(Zo6, GTO's, WS6)
Napper is offline   Reply With Quote
Old 09-04-2010, 06:43 PM   #11
Napper
Napper's Avatar
Not interested in trades are ya?
2010 CTS-V books for 49-51k trade in!!
Old 09-06-2010, 02:41 PM   #12
Archangel
Archangel's Avatar
Drives: 1999 GMC Sierra Z71
damn if this was november I could buy it off you. well good luck to you man, it is an awesome machine. i love that engine
Everyone is entitled to their own opinion no matter how wrong they are
If I agreed with you then we would both be wrong
Archangel is offline   Reply With Quote
Old 09-15-2010, 08:46 PM   #13
Napper
Napper's Avatar
help me sell my 2 SS/rs auto maggie/ adm intake/ Kook headers/ kooks back
Eibach springs and sways, pfadt endlinks, LSr trailing arms, toelinks
tunnel brace,
1500 miles made 460 - 490 on a mustang dyno at safe 7 psi.
Silver with stripes...
looking for 32k 33k firm......then i give you the rest. CASH
help with shipping.
Old 09-17-2010, 11:26 PM   #14
Speedfreak
Drives: 1999 30th Anniversary Trans Am
tunnel brace,
help with shipping.
damn, what a deal.
Speedfreak is offline   Reply With Quote
2010 SSRS IOM LS3 is now on EBAY! 2010SSRS Autos For Sale / Wanted 1 07-05-2010 02:19 PM
SEMA CAMARO: LS7 Camaro Tran Camaro Photos | Spyshots | Video | Media Gallery 157 10-16-2009 10:26 AM
G-Force 454 LS7 2010 Camaro!!! Robert@G-Force Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 08-18-2009 12:12 AM
** Videos *** SEMA 2010 Camaros: Black, LS7, Dale Jr nmrajames Camaro Photos | Spyshots | Video | Media Gallery 5 11-06-2008 12:16 PM
