Solo Performance
Old 11-24-2008, 03:09 PM   #1
devildogcollier
semper fidelis
Drives: 95 z28 lt1 6-sp,73' nova 350
can anyone tell me what kind of performance i could expect from a stock 1995 z28 6-speed manual i am about to acquire?????
devildogcollier is offline   Reply With Quote
Old 11-24-2008, 03:34 PM   #2
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
High 13's to low 14's in the quarter mile if stock.
2010 IOM Camaro 2SS/RS manual trans
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is online now   Reply With Quote
Old 11-24-2008, 03:37 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Great driver, healthy car, good tires = high 13s stock.
Okay driver, healthy car, good tires = low 14s stock.
FWIW - I'd make sure the water pump is in good condition; if it's been replaced, that means it's leaked all over the distributor and make sure that's been changed too. Also, the intakes liked leaking oil and there's a special silicone GM had offered specifically for this problem. Check into those and I think, for the most part, you'll be a happy buyer.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 11-24-2008, 03:40 PM   #4
devildogcollier
semper fidelis
upgrades
how much do you think it would cost to put some decent headers ,good air intake and to cam it out"???? also what kind of output would i be looking at then?????
Old 11-24-2008, 04:28 PM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
intake can be as cheap as you want. ive seen PVC custom intakes for 400rwhp LT1s, get a good filter and look around for a decently priced CAI.
exhaust, check out www.herronperformance.com Ceramic coated pacesetter longtube headers and off road y-pipe for right around $500.00
cam, depending on what you want, you will need to replace the lifters, springs, valve seals, retainers, seats, might as well swap out the rockers and pushrods as well. cc503 and the 847 cams are about as big as you can go on stock heads tho.
whats your budget and what are your goals?
I piss excellence
and fart awesomeness
Old 11-25-2008, 02:20 PM   #6
devildogcollier
semper fidelis
goals
i dont want a drag car cause its gonna be an almost everyday driver....but i want to feel confident that if i pull up to a mustang gt ill be able to take it..... i dont want to spend more than $3000 right now...ive just never owned one of these types of camaros so i dont know what its potential is.... i just want to get as much hp as i can with $3000
thanks
Old 11-25-2008, 04:29 PM   #7
jeremy02
Drives: 1999 Red Z28
I'd look for a used LS1 and do an engine swap rather then mod the LT1. You'll love it, man.
www.car-parts.com, you can use this website to search junkyards in your area.
jeremy02 is offline   Reply With Quote
Old 11-26-2008, 05:54 AM   #8
devildogcollier
semper fidelis
thanks
thanks for the help guys
semper fi
Old 11-26-2008, 03:44 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If you have a buddy who wrenches, and don't have to worry about smog, you can also think about seeing if there's still an LT4 converstion kit.
http://paceperformance.com/index.asp...&Category=7063
Old 11-29-2008, 06:37 PM   #10
CamaroSpike23
Truth Enforcer
going thru the trouble to get an LS1 in there would be a waste. you can do a lot to an LT1 with $3k.
thanks
heads and a cam.
http://www.advancedinduction.com/AiProductsLT1.html
then look to suspension mods, like subframe connectors, double adjustable lower control arms, adj panhard bar, lca relocation brackets, aftermarket t/a.
in fact, if you got the money now, www.herronperformance.com is having a 20% off sale on all UMI stuff.
I piss excellence
Old 11-29-2008, 09:03 PM   #11
Az Sparky
Drives: 74 Camaro, 91 Caddy
you could leave the engine alone and put a sts turbo (single) setup for. then you could run low boost 5psi around town and put into high boost when that mustang pulls next to you.... he wont know what happen youll be going past 100 before he hits 60 LOL.....
Az Sparky is offline   Reply With Quote
Old 11-29-2008, 09:30 PM   #12
CamaroSpike23
Truth Enforcer
yeah, but the camaro system is 4k.... and he's only wanting to spend 3....
I piss excellence
Old 11-29-2008, 10:30 PM   #13
jeremy02
I still say engine swap. You can easily get away with it for 3K and the change will be ridiculous.
Old 11-30-2008, 05:09 PM   #14
CamaroSpike23
Truth Enforcer
but you wouldnt just be swapping the motor, you've got to swap the trans, heater hoses, k-member, suspension, fuel pump, pressure regulator, vss, vats simulator, plus you have to modify the way the radiator is setup as the LS1 cars have the radiator sitting more upright than the LT1 cars do.
or you can spend that 3k on a heads/cam/intake setup and bolt-ons and walk most LS1s all day long.
I piss excellence
