HeadlightArmor
Old 08-09-2010, 08:25 PM   #1
Spiffyguitar
Spiffyguitar's Avatar
Drives: 2010 Camaro 2SS/RS
Thew check engine light... need help!!
Ok... So a few thousand miles ago I removed my secondary cats. In the process I used a 02 sensor socket to remove the 4 sensors instead of unplugging the sensors from the top. There was some twist in the cable, but when I reinstalled everything I counter twisted the cables first to take the tension off.
I still have my primary cats in... and have been driving trouble free for a few thousand miles. Now all the sudden I get a check engine light a couple days ago. It was on for a little bit, then went off on it's own. Now it's back randomly... so I thew in a reader and got the code...
"P0134 02 sensor- no activity detected, bank 1 sensor 1"
So did the car just take a few thousand miles to figure out the secondary cats are gone, or did I damage a sensor? I'm a bit confused because 1.) The sensors are before/after the primary cat, and the secondary cat isn't metered. 2.) If I did damage an 02 sensor why would it take thousands of miles to show up?
Either way it won't be covered under warranty since I removed the secondaries, so no point in taking it to a dealer.
Can someone help me out??
2010 Camaro 2SS/RS -6M
397whp/393 ft/lbs
Spiffyguitar is offline   Reply With Quote
Old 08-09-2010, 08:37 PM   #2
jtzako
Drives: 2010 IBM Camaro SS
It wont take that long for it to 'figure it out'.. when I had mine unplugged briefly it only took about 30 miles.
Chances are it has either gone unplugged again, or the vibrations finally shook loose an already damaged wire.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 08-09-2010, 08:47 PM   #3
R1CH
R1CH's Avatar
Drives: 2010 CGM 2SS/RS 6M
It won't throw a code from removing the rear cats... EVER
R1CH is offline   Reply With Quote
Old 08-09-2010, 11:19 PM   #4
Spiffyguitar
That's what I was thinking, because they are completely unmetered.
So dumb question for whoever knows... is bank 1 sensor 1 the driver side sensor pre-cat?
397whp/393 ft/lbs
Old 08-10-2010, 01:16 AM   #5
3min3m2
3min3m2's Avatar
Drives: 2011 2SS/RS SIM L-99
I would say that or pass side rear 02. Depends if it starts at 1 or 0...
3rd Time is the charm
2012 2SS/RS VR 6M.
Borla S type, Volant CAI.
3min3m2 is offline   Reply With Quote
Old 08-10-2010, 01:24 AM   #6
Spiffyguitar
Makes sense... so maybe something like
Bank0- drivers side, sensor 0=front, sensor1= rear
Bank1- pass side, sensor 0=front, sensor1=rear
Can anyone confirm?
397whp/393 ft/lbs
Old 08-10-2010, 01:35 AM   #7
3min3m2
3min3m2's Avatar
According to obd-codes.com, it's 1 then 2 so it's most likely drivers side primary.
2012 2SS/RS VR 6M.
Old 08-10-2010, 03:26 AM   #8
Spiffyguitar
Cool... that gives me a place to start.
397whp/393 ft/lbs
Will LT headers cause check engine light? jpizzle007 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 06-03-2010 03:22 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
One Tire Fire and Check Engine Light?? Any Ideas?? DARK2SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 02-26-2010 01:45 PM
Help with Check Engine Light after tune jrpxxii Tuning / Diagnostics -- engine and transmission 8 11-06-2009 06:37 PM
