AAC Style
Old 08-10-2010, 01:24 AM   #1
David79z28
David79z28's Avatar
Drives: 79Z28 and 2010 2SS/RS
Surging/ hesitation
I have a 2010 SS with an A6 trans. I started noticing the car hesitating/ surging when I turned the cruise on at 70 mph. My dealer experienced it also while driving my car. However, they could not figure out what to do to fix it. They felt that the car was between 5th and 6th gears, causing the converter not to fully lock up for a few seconds.
Now the car is doing this at any sustained speed even when the cruise is off. So that theory is shot!!!
Anyone else experience this? If so, what was the fix?
Any techs seen this yet?
I would like to help the dealer find the solution if possible.
David79z28 is offline   Reply With Quote
Old 09-22-2010, 06:22 AM   #2
fsugreg
Drives: Red jewel tint
I have a 2011 2ss that also hesitates and surges at any sustained speed. It also does this with slight acceleration. I also went to the dealer. All they would tell me is that everything is within parameters. It feels like the timing is slightly off.
This can't be normal operation. I find it hard to believe that GM could possibly think this is acceptable. I sure hope someone comes up with some suggestions for a fix.
fsugreg is offline   Reply With Quote
Old 09-22-2010, 08:14 AM   #3
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Possible bad gas. Have you tried the 5 and 20 fuse pull in the engine bay. If you are running lower than 91 octane you will have issues. Also the computer will dump to the low octane full table to keep from blowing the engine. Problem is once done there the car does not relearn well.
Run you tank to almost dry. Go get 91 or higher octane gas from a name brand busy station. The do overnight fuse pull and report back to us.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-22-2010, 11:01 AM   #4
ffrcobra_65
could be the engine switching back and forth between 8 cyl to 4 cyl which is normal for L99.
Old 09-22-2010, 01:00 PM   #5
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
It happens with mine also and I think it is the crappy AFM.
cmore is offline   Reply With Quote
Old 09-23-2010, 09:38 AM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
fsugreg, you could also take the vehicle to another dealership for a second opinion on this issue as well. I hope the suggestions here help you!
Jeff Morris, Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 09-23-2010, 01:33 PM   #7
David79z28
David79z28's Avatar
I just got a call from a Josh at Chevrolet Cust Svc stating again that this is normal. Why should we waste our time with another dealer if Chevy won't do anything?
Old 09-24-2010, 09:01 AM   #8
fsugreg
I always put 93 octane in. Car is at a different dealer now. They feel the hesitation, and first thought is that the fuel on demand (shutting fuel off to four cylinders) is kicking in pre-maturely. They have my car now, and are going to re-evaluate the parameters to try to fix it. I'll let you know.
Old 09-25-2010, 07:31 PM   #9
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
I have a maggie with afm off and still have this same issue with custom tune. I am leaning more toward transmission tune/torque converter!
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 09-26-2010, 09:44 PM   #10
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Mine does it too on occasion, but also when shifting down from speed. It's the transmissions, I'm not sure why, but the new auto transmissions are not great. I had the same issues, but worse with Dodge Magnum RT auto. Service doesn't have a clue what to do if the car isn't throwing a code and Chevy won't pay for what they need to do, which is open it up and see what the friggin issue is.
So Cal Camaro is offline   Reply With Quote
Old 09-26-2010, 10:15 PM   #11
Snake skinner
Drives: 2010 black camaro ss
Did you check to make sure your maf hasn't gone bad, I over oiled my k&n air filter and the red oil got on the maf and caused it to crap out, giving me similar symptoms.
Snake skinner is offline   Reply With Quote
Old 09-27-2010, 04:00 PM   #12
Drives: GM Vehicles
David79z28, could you send your case number so that I can review it? Also when we give our customers the resolution for their case we are given (most times) the resolution from the dealership as per their diagnosis of your vehicle and situation at the time. This is why in some cases we do suggest that you take your vehicle to another dealership to see if the other dealership can offer any insight into the problem with the vehicle and possibly give a different resolution. It doesn't work all the time but many times it has been a determining factor in positive outcomes. I hope that answers your question. I hope to hear from you soon.
Old 09-27-2010, 04:24 PM   #13
sub zero
sub zero's Avatar
Drives: RED@2SS
i have same problem in my l99 , i feel the hesitates in the first monthes but i'm didn't take it in seriously because it was happening to me at low speed and i dedn't changed my exhaust that time , but now i change my exhaust system and usually i drive my car in high way and i'm just feeling the hesitates and with the new exhaust it make high noise during driving and i feel that noise aulso when i puting in cruise control at 140km , i thought this noise comes from the exhaust at the beginning ..
the thing which i'm not know why it's happen , during i'm driving in high speed and the cruise control worked in 140km , i try to change the gear shift to manual and the sound is just desappeared !!
i hated the automatic gear after happen to me this problem specialy with MAGNAFLOW exhaust the sound come huge !!
sub zero is offline   Reply With Quote
Old 09-27-2010, 04:34 PM   #14
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
If any of you can pul out your MAF and let me know the ID it has on the blk plastic There is some thing that i learned today And if you post and it is what i think then you need a new MAF.
Hesitation / Slipping jachevy28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 30 10-21-2015 10:18 PM
Surging when cold? SSSoon Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 08-11-2010 09:26 PM
Hesitation on cold starts? Captain McFunk 5th Gen Camaro SS LS LT General Discussions 8 04-28-2010 12:31 PM
