gotta say thanks to all the people who had the ingenuity to try and make these mods simple to do and work well. Did this mod and couldn't be happier
AMAZING!!
4 Attachment(s)
THANKS SO MUCH TONYNO!!!
I've never done ANYTHING with wiring before, and I did this all by myself, and was shocked that it actually worked. I followed the instructions to the letter and with a little help from google got everything wired correctly. Installed the dome/trunk light as well. Matches my RJT perfectly! Pics (iPhone camera) - |
Good job all!
Great thread TonyNo! Floor lights installed... What I'd like to do is get a 12v powerline (switched on/off with ignition) to go to a SPDT relay so that my floor lights will kick on with either the dome light or with the ABL.
Tony, can you point me towards a place to tap that powerline? I did a search but I am not finding what I need.... THANKS in advance! |
Thanks! |
13lade: Do you mean the dome light wire at the BCM that is mentioned and pictured in the first post? ;)
PostaL: Just the smallest fuse that I could find locally. Mine was 2A. These LED's only draw milliamps. |
Just finished, worked like a charm!
You rock Tony, next beer is on me :drinking: |
Sorry... i should have been more specific... I meant a 12v switched that is not switching off with the domelight switch. :) |
I just knocked this mod out in maybe 30 minutes. It is so simple. Great instructions and pics.
Can you turn this off and on?
so attempted the install today and i failed miserably lol. i had the CCFL tubes from AAC and for some reason it didnt turn on. i pretty sure i did everything right from the grey wire(from the grey connector) to the two black wires for the ground. im suppose to connect the two red wires from the (2) inverters to the grey wire on the grey connector right? i did that and i really have no clue why its NOT WORKING!! sigh........
I never saw the AAC stuff, so I can't comment on that.
Dyk-NO: I did post a diagram earlier that showed how to connect a switch to get that functionality. 13lade: Maybe you can find the radio power wire in the diagrams and tap into that? |
That was an easy 10 min install! :-) Hooray DIY people! PS. I went blue.. Blue on black is my new theme.. I want IBM stripes instead of my silver! :-O
