I'm at 637/580 with a LSA supercharger, 2.75 pulley, BTR Stage 1 PD cam and matching valve springs, 65lb injectors, ZL-1 fuel pump, ADM FPCM, ADM CAI with scoop, Kooks LT headers and magnaflow 3" catback. ADM Performance did my blower install and tune.
700rwhp is very obtainable with a Eaton blower but you will need to make sure you motor is efficent...heads, cam, etc.., We can get you into a TVS2300 for a very realistic price. Our shop car is pushing 602rwhp with minimal mods (headers/intake) with an SLP blower. We will be marketing this kit pretty soon as well.
The shop I use has had several cars break the 700rwhp mark on their Mustang dyno. I'm pretty sure all were using meth and E-85 to get over the hump.
You don't need heads to do it but you will need a really good fuel system, E-85 conversion and meth to get there along with headers, upper and lower pulley swap and a good tuner. I'll be there on Tuesday when I get tuned with my Maggie. Sent from my iPhone using Tapatalk |
700 rwhp
700 rwhp is not safe on factory pistons,rods,bearings no matter what power adder in my opinion.
600-650 is the norm for most ls3 engines. |
Agree. Once you pass 650 anything can happen.
Here's my plan. 15 1le NPP exhaust. Goal is 650rwp. Let me know if you would do anything different (no I'm not going twins).
LSA supercharger (purchased) ADM kit (purchased) ADM 2.50 pulley Ported blower/snout Ported throttle body 1-7/8" Headers no cats Cam Motion 226/240 .613/.604 114+3 8620 core (purchased) BTR valve springs Pushrods - length tbd Comp Trunion upgrade Cam install parts Boost-A-Pump (open to suggestions) 85# injectors (should be sufficient for 650???) D3 heat exchanger D3 coolant reservoir H-E clutch BMR trailing arms/bushings Differential bushings other BMR suspension goodies |
I would suggest a ZL-1 fuel pump and FPCM combo and ID-850s over the drilled out 85lb stuff that is out there. Everything else seems in line. Good luck with your build, and if there is anything you need help with don't hesitate to contact JRE. Ted. |
Agreed with Ted on fuel stuff.
If money is no concern, look into flex fuel, and maybe a nice set of ported/done up LSA heads. |
2 Attachment(s)
Looks like a winning combo
All those parts will work nice together. If you need anything fell free to give me a shout :first:
