Nor Cal ZL1 |
10-07-2016 09:45 AM |
Originally Posted by samman11
(Post 9346858)
Tell me about this "kill switch." What is it, who installs it, how much, and how does it work better. thank you.
Kill switch is a random personal install usually located in an unusual location. Typically used to interrupt the fuel, or ignition systems, but can also be set up to disable battery operation upon an unwanted attempt to start the car. The switch can be as simple as a toggle switch, to a relay system requiring a certain other device to be powered to allow the starter to operate. It can be as simple or as elaborate as you want.
Someone to install it would be able to understand schematics and sequence of operation in order to identify the best way to personalize a kill switch. If you can't do this, I would suggest a mechanic specializing in electrical systems, or dealership, over an alarm installer. If your good with schematics I would look for opportunities to interrupt the fuel system or ignition in a location that is NOT under the hood, or in an otherwise obvious location.
How it works better is it is RANDOM and not suspected. Thieves are not going to spend a bunch of time troubleshooting why a car won't start. With Ravelco they have a single system to solve. For that they could simply purchase one and reverse engineer it to build a quick install bypass harness.
