My tuner believes my TPIS is causing tuning issues. It doesn't always seem to respond to tuning commands. The idle varies from time to time and the car has gone in to reduced power mode twice while driving. I'm not talking WOT either. A couple of nights ago, it did it while I was slowing down to turn in to my driveway. WOT has been fine.
Without a scan file of the event, it's guess work.
I spoke to Jim at TPIS. He said he's seen this issue before and he knows what's wrong with it. I'm going to send it in for repair.
We have sent our TPIS and our NW in for repair, and both still do not operate well with anything more than about 15 psi of boost. We have switched back to the stock 90mm and have not had any issues. Both 102's will be going back for repair and be used on N/A builds instead.
it would always go into reduced power around 3000rpm when letting off the gas pedal ...for instance , driving down i95 at 80, and completely letting off the gas , would throw code and i would have to pull over , shut off engine , wait a couple minutes and it would reset...
2 - Holley LS Modular "Hi–Ram" EFI 92/102mm Throttle Body Gasket PART #: 508-20 4 - Longer stainless screws/studs w/nuts (1/2" longer) |
My NW102 has worked perfect since I made the changes, the TPIS is quite a bit more $ but there is not a lot of choices. I was heading that way next though. I have a brand new 90mm that I ported and never installed, maybe I should sell it.
2012 ZL1
Interesting reading. Having problems with reduced power as well with NW102. All my codes are coming at fairly low speed/partial throttles and will sometimes not clear at all until the car sits. It started with a 2135 two different times and then after I cleared it threw out 1516 and 2119 and then cleared and got 0606, 0607, 1516, 2119. Car is making about 17psi and around 750 rwp. Runs perfect under wot and it doesn't do it every time. It wents days without repeating although its getting more frequent now.
