27.5” front skinny, 29” rear . Any issues down the track
Any body these size tires on the 1/4 mile track. Any issues with the diameter sizes. Want to know before I order some tires.
According to website skinny is 27,8” and rear is 28.8” so 3.48% diameter difference?
I have mainly seen people say no more than half an inch difference otherwise it sets ABS but I don't know the limits
I am 3% different on my street tires and zero issues.
I'm running 27" in the front and 28" in the back and the computer was not a fan. Had to pull the fuses.
Sent from my Pixel using Tapatalk |
Any issues racing down the track with fuses pulled? |
I pulled fuses on mine spun just a hair on the launch and it knocked the rev limiter down to 5000 I was waiting for my shift light at 6200.... put them back and problem solved. I would prefer to have them pulled so I don’t have to disable traction control plus I liked the steering better. Idk how to fix that problem though
When I pulled fuses I could no longer do a burnout. Best to match tire sizes and not create new issues.
I think the biggest difference people go is 3%. 285/35/20 and 315/35/20. You might be okay with your selections. Might. You a gambler?
Tune out traction control for the drag strip. I ran 315/35/17 25" rears and stock fronts. Fuses pulled zero issues. Mine was a 2015
Have no clue why mine did what it did only if I spun a little bit. I don’t spin much when I launch. I wonder if you just disconnect the sensors if that would work better...???? No idea
I have been racing with the fuses pulled for a couple years. Heck my ABS has not even worked for the last year I think we broke a sensor.
But 27 front and 29 rear will will most likely trigger ABS. |
I run the 28" Mickey radials up front with 29x11.5x15 qtps on the rear without tripping the abs light . When I put the 29.5x10.5 radials on it will trip the abs service lights etc. I only use the radials at the track when the fuses are pulled.
think the 2 options I might go with are (MT ET front tire 27.5"x4-17 with MT ET Street S/S 305/40r18) OR (M&H skinny radial 4.5/28r/17 and MT ET Street"R" 305/45r.18) this way I keep everything under or near the 3% difference
The only problem is that when service stabailitrac comes on, it disables power steering for the later model years that have EPS (electronic power steering) unless there is another way around it.
Sent from my VS988 using Tapatalk |
While going through gears.
I’ll have to try to find that.
I don’t like having to turn off traction control either I tried to have the shop tune the abs and stabilatrack to be off as default but they said that they were not able to do that because it’s part of the body control module. |
I've been racing with the fuses pulled for couple years. My car even with both turned off would still have the ABS 'pulse' on me during the burnouts, and in 1st gear during a pass.
5% is the maw difference with the rear being larger. Go larger in the front and the computers get very unhappy.
Well decided my route. Ordered Mickey Thompson ET Street “R” 305/45/18 rears and the new M&H radial front runner 4.5/28r-17
Well my skinnies showed up except they are not the radials DOT. They sent me the same size except a bais ply DOT. Oh well might just run them anyways.
Information I found on the front tires. "M&H bias ply front runner in 28x4.5-17 size has a load rating of 1325lbs" which is more then a lot of other front runners.
1 Attachment(s)
1 Attachment(s)
Car is now all set up and ready to go. Hopefully test them in a month or so
Attachment 931624 |
waiting on test results. curious to see if your abs trips like mine did with same setup.
