Expected boost drop going to 2" LT
I had installed shorty header and high flow cats back before any plans of super charging. After installing my v-3 with a 3.33 pully I knew it was only a matter of time before the cats went just curious about how much boost I'd expect to drop? I was right at 10 at 6500
I would say maybe 1psi
Thanks
had exact set up...I'd bet if you are seeing 10psi with cats on a 3.33 you have an intake restriction. So, put the 2" headers on and drop 1-2, but put an ECS filter on the head unit and pick up just about that. Should keep you around 10psi. ECS or FSP can sell you the filter.
don't do 2" headers with 10psi! stick with the 1 7/8
^ explain why
The ballpark to when you should move to 2" is about 800rwhp |
Yep cars going from dd to track only over the next year just figured I'd go for the 2" now
I saw people gain hp switching from 1 7/8 to 1 3/4 on LS7's go figure. http://ls1tech.com/forums/generation...xperience.html This is a SMALL example, do a search and you will find the answers you're looking for :) |
1 7/8ths is plenty. At 650whp FI kooks 1 7/8ths headers only gained me 5%. No cats in either comparison.
Doing a heads cam build on my ls6 now targeting 450-470 whp (if it was an ls3 this combo would yield about 50-60whp more), keeping the 1.75 longtubes I have now for this. |
I had 1 7/8" but recommend 2" for any FI now. No reason to upgrade later and I haven't seen any power/torque loss on a good set of them.
I don't know what happened with mine but have a Procharger making 6-6.5 psi and 480 rwhp (no special tune, all stock other than cat back). After installing headers (no tune) I lost 3-3.5 psi and no one knows why I lost so much it wasn't common.
