Pre-delivery inspection form
If you've ordered your Camaro (as opposed to buying one off of the lot), does the dealer go through each of these punch-list items in your presence, or is this done before you arrive to take delivery?
http://www.gmhouston.com/pdi/2010Camaro.pdf Note that your signature is required at the bottom of the form that the inspection actually took place. :paddle: |
We PDI the car when it comes off the truck and then put it on the lot to be sold. All it wants is the techs sig and the managers sig at the bottom. I check everything off if I look at it or not. Generally it doesn't pay too greta so we put the plate brackets, hub caps, antennas, fuses, and set compasses to read proper zones. If there is an issue, WARRANTY. Its our annoying gravy work.
So, if the car is actually LOOKED AT, you won't know unless you request them to do it infront of you like I did. |
All of our PDI work is done prior to delivery to the customer. I have had customers request to go on the initial test drive with the tech just to make sure how its driven.
If you know when your Camaro comes in ask the service manager if you can be present for the inspection. You really wont see much though.
