Boston Acoustics Speaker Ratings
I've searched high and low and cannot find the answer.
Does anyone know the specks of the BA speakers. I'm looking for RMS/Peak handling and I guess ohms. I am trying to plan an audio upgrade and I am trying to figure out how much to push to the stock speakers or figure out if I should upgrade them. Thanks. |
You can safely push more power to the stock BA speakers with an amp such as the JL Audio xd400.
Unfortunately, I don't have the specs of the BA speakers. But for best results, you should just replace the speakers with some that can handle more power. |
guessing 25w RMS 50w max, entry level stuff.
Has anybody been able to find the specs on the BA speakers?
If you are upgrading anything at all in the audio system, there is no way you should keep the stock speakers. You can find upgraded speakers for under $20 each if you look. Don’t waste your valuable time searching for specs on the OEM speakers.
I pulled the BA amp, dropped in an Alpine PDR-V75... HUGE difference! :nod:
Silver Flute W17RC38-04 $29.80 each Peerless 830657 SDS Woofer $21.70 each Peerless PPB 830874 $27.00 each I would recommend in that order. |
Thanks!
I’m probably just going to save up and do the amp and the front speakers at the same time. |
I really am not into removing like the whole dash but would like a little better sound. |
The amp is in the trunk right behind drivers side tail light. Easy to get to.
