Knocking when slowing down?
Seems when i'm rolling at a low speed with the clutch engaged a knocking is coming from the transmission. Any help appreciated
yes, take it in for warranty, mine did this as well and after them having it three days telling me parts were ordered on the 4th I called they said forget the parts your getting a new tranny, seems the either didn't know what was wrong or there was too much wrong. My husband who was amaster ASE tech said he thought it was the output shaft bearing but they neither confirmed or denied what was actually wrong but I got a new tranny at 8000 Miles, so far no more noise.
I know that the output shaft has been replaced at around 12,000 miles and the car has 15,000 miles now. Maybe they didnt fix it right the first time. Thanks for the information
You may want to check for loose drive shaft bolts.
when you put it in neutral and let off the clutch does it still make the noise? can you hear anything then?
