What is under the gas door cover?
Like the title says. What is under the chrome gas door cover? The cover appears to be crimped on or something. I was just wondering if I take the chrome piece off if I have a flush fitting cover in body color (the inside of the door is).
Most of the chrome gas doors replace the stock fuel door.. they just slide and pop off
Is that what you mean? |
1 Attachment(s)
Yes... here is a picture to help you take it off
Would help to have a pic of what your talking about, picture is worth a thousand words.
Apparently not all cars came with them. The last three I have seen around here have them. |
1 Attachment(s)
This is the fuel door cover you're referring to correct?..if it is ..your stock door was removed and replaced with this ..and also the bolts are not fake..they can be removed if you decide to paint it or something.
This is what I am talking about
https://uploads.tapatalk-cdn.com/201...27d7332df0.jpghttps://uploads.tapatalk-cdn.com/201...6eba37e75d.jpg Sent from my SAMSUNG-SM-G890A using Tapatalk |
That just looks a fake stick on one. Looks like it just can be pried off, but I don't know the shape of the fuel door underneath.
Oh yeah that's a cheaper aftermarket one held on with 3m tape..try warming it up with a heat gun..be careful and should be able to remove it from your stock fuel door
I've seen these on several cars so I assumed it was factory. Worse case scenario I can always stick it back on.
