GTS trunk blackout panel?
Wondering if anyone has tried the GTS smoked trunk blackout panel?
blackout kit
2 Attachment(s)
YEP not a real closeup shot, but here you go. the panel is very difficult to line up so take your time.
I have to say that you did a real nice job accessorising your car
I had the entire GTS blackout kit including the rear panel. The cut-out is bigger than the bowtie so body color shows around the bowtie unless you cover it somehow. Also the panel taped on and it did trap moisture and debris underneath it...so I pitched it. A vinyl stripe is cheaper and a better long term solution IMO. http://i448.photobucket.com/albums/q...mbs-up_new.gif
1 Attachment(s)
GTS trunk blackout
Paint it :) no problems then ...
