Trying to uninstall stock air box
1 Attachment(s)
How do i remove this?
If I remember correctly, pulls straight up. It's been years since I swapped mine to the z28 cai, but i remember it pulling straight up
Thanks ill try that
It worked!... now to remove that air flow sensor
good to hear buddy. what system are you swapping to?
Isn't this forum great? You ask a question, a few minutes later, problem solved.
I would. I remember with CAI, one of the bolt heads was left unused, but the z28 used all oem locations. I believe regardless, you should still be able to snap it back into it's original location. Sorry, again going off memory, but I had both CAI and Z28 my car
1 Attachment(s)
Im having trouble sliding this hose
heat up the hose with a heat gun on low, spray wd40 on the plastic piece end. Line up, push hard and that will do it
Damn i dont have one, will a hair drier work?
that will do. keep it on high for a bit
Thanks bro
