yeah, they haven't touched it-the first drip on my floor and they're tearing it down. I check it once a week now- and it's currently covered again from when they cleaned the underbody last week. all bolts are torqued properly
I should of snapped a picture of mine before cleaning it up. . .
I had a leak in my secondary oil cooler, took the dealer a whole 20 minutes to fix. (After the 20 minutes I had to explain WHY I was under the car in the first place).......Really?:paddle:
I wonder what face the service writer would make after that. |
I had mine in 2 months ago and they replaced the oil cooler adaptor gasket. Just was under the car today and there is a light coating of fresh oil under the oil cooler again,WTF! Also, the pan has drips at the rear. This looks to be a rear main because it wasn't running down from the oil cooler. It's going in again next week! Brand new $37,000 sports cars should NEVER have oil leaks with only 6000 miles! I HATE cars with oil leaks, don't you?
i had two oil leaks. one at the oil cooler, and another leak from the front and from the back of the oil pan.
Service Bulletin: #05-06-01-034K: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L-Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) - (Apr 8, 2010)
Models: 2004-2007 Buick Rainier 2008-2009 Buick LaCrosse Super, Allure Super (Canada Only) 2005-2010 Cadillac CTS-V 2007-2010 Cadillac Escalade, Escalade ESV, Escalade EXT 2003-2009 Chevrolet TrailBlazer 2003-2010 Chevrolet Corvette 2004-2006 Chevrolet SSR 2005-2010 Chevrolet Silverado, Silverado SS 2006-2007 Chevrolet Monte Carlo SS 2006-2009 Chevrolet TrailBlazer SS, Impala SS 2007-2010 Chevrolet Avalanche, Suburban, Tahoe 2009-2010 Chevrolet Colorado Pickup 2010 Chevrolet Camaro 2003-2009 GMC Envoy 2003-2010 GMC Sierra 2004-2005 GMC Envoy XUV 2007-2010 GMC Yukon XL, Yukon Denali, Yukon XL Denali 2009-2010 GMC Canyon 2004-2006 Pontiac GTO 2005-2008 Pontiac Grand Prix GXP 2008-2009 Pontiac G8 GT 2009 Pontiac G8 GXP 2005-2009 Saab 9-7X 5.3i 2008-2009 Saab 9-7X Aero 2003-2010 HUMMER H2 2006-2010 HUMMER H3 with 5.3L, 5.7L, 6.0L, 6.2L, 7.0L VORTEC™ GEN III or GEN IV V8 Engine (All Aluminum Block) (RPOs L33, LC9, LH6, LH8, LH9, LM4, LS4, LS1, LS6, L76, L77, LFA, LZ1, LS2, L92, L94, L99, L9H, LS3, LS9, LSA, LS7) -------------------------------------------------------------------------------- This bulletin is being revised to add labor time information for the Colorado and Canyon. Please discard Corporate Bulletin Number 05-06-01-034J (Section 06 - Engine/Propulsion System). -------------------------------------------------------------------------------- Condition Some customers may comment on an engine oil leak. Cause Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only. Correction Follow the steps for Oil Leak Diagnosis in SI to determine the source of the leak. If the leak has been diagnosed as coming from the engine rear cover assembly, refer to Engine Rear Cover Replacement in SI and remove the engine rear cover assembly. Inspect the engine block and engine rear cover for porosity on the mating surfaces. • If porosity is found on the engine rear cover (see illustration below), replace the engine rear cover assembly, GM P/N 12633579. • If porosity is found on the engine block, use the following procedure to apply RTV to repair the engine block porosity. The porosity issue is in the gasket sealing surface at the top of the cover, near the high pressure oil crossover port. Refer to the picture below. The oil leaks by the gasket and runs down the side of the cover, and may appear to be a leak at the t-joint area of the cover. The fix is to replace the cover with GM P/N 12633579. Also, if porosity is found anywhere on the sealing surface of the engine block, use the following procedure to apply RTV to repair the engine block porosity. Refer to the illustration below. Important: Clean any residual oil from the block and cover before applying the sealant in the next step. •Wipe a small amount of RTV, P/N 12378521 (in Canada, use P/N 88901148), onto the surface using a plastic scraper to fill the porosity. •Remove any excess RTV material, especially from inside the high pressure oil passage. Refer to #1 in the above illustration. •The joint may be closed immediately after applying the RTV. Total joint time after the RTV has been applied must be under 20 minutes. Important: Refer to Engine Rear Cover Replacement in SI and follow the tightening specifications and sequence. •Reinstall the engine rear cover using a new gasket and a new crankshaft rear main seal. Refer to Engine Rear Cover Replacement in SI. Parts Information Important: For Saab (U.S.) only, use P/N 88861206 - Engine Oil Dye (U.S.) or equivalent. Part Number Description Qty 12574293 Gasket - Crankshaft Rear Oil Seal Housing 1 89060436 Seal, Crankshaft Rear Main 1 12378521 (in Canada, use 88901148) Sealant 1 88861206 (in Canada, use 88861259) Dye, Engine Oil 1 12633579 Housing Asm-Rear Cover 1 |
