Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (https://www.camaro5.com/forums/index.php)
-   Camaro DIY & HOW-TO instructions & discussions (https://www.camaro5.com/forums/forumdisplay.php?f=67)
-   -   New way to remove sub frame bushings! (https://www.camaro5.com/forums/showthread.php?t=481194)
BurnedRubber 01-20-2017 10:46 AM
1 Attachment(s)
Hello everyone! I recently changed the rear sub-frame bushings on my Camaro. Many people suggested I use the method of heating the bushing and allowing the weight of the car force the bushing from the sub-frame. When I was thinking about this and watching videos of others doing this I didnt really think it was the right way to do it, and wasnt really comfortable with moving the car around like that with the rear end out. I triend BMRs suggested bash the hell out of it with a hammer method and that was verry innefective. So what i did was use the heat method with my own twist.
Tools required
- 2 Jaw balancer puller (a set of 3 can be bought from harbour freight for fairly cheap)
- 1/2" drive ratchet
- Socket to fit on the balancer puller
- Short extension that fits in the metal center of the bushings
- Propane torch
Steps
- First you are going to want to place the small extension in the metal center of the bushing, this will help center the puller
- Second, your going to want to put the puller on the extension, were using the puller to push the bushing out, opposite of its intended purose.
- Third, use the ratchet and socket to get some light pressure on the bushing.
- Fourth, start applying heat with the torch to the metal sub frame surrounding the bushing
- As you apply heat, slowly tighten the puller, trying to keep it as verticle as possible, be aware if it gets a lot of angle. If it does start to go crooked stop, and re position and start again.
I hope this helps! if you have any questions please ask them here or feel free to PM me!
:thanks:
olblue75 01-20-2017 11:27 AM
So you dropped the whole rear subframe???
BurnedRubber 01-20-2017 01:58 PM
Yes, I had to drop it to do some other bushings so I did everything with it out.
camaro500 01-20-2017 02:00 PM
Cool!
BurnedRubber 01-20-2017 02:15 PM
Originally Posted by camaro500 (Post 9516036)
Cool!
Thank you!
JLSuperfly 01-20-2017 03:13 PM
Nice DIY write up. Thanks for sharing.
olblue75 01-20-2017 03:17 PM
Looks a lot easier!!! Good info!
davidscamaro 01-20-2017 03:44 PM
Looks way cleaner than using the cradle still in car way I did, got pretty smokey burning them out with just the weight of the car to push the bushings out
BurnedRubber 01-20-2017 04:15 PM
It worked really well. I think its a lot safer than using the weight of the car like many do! maybe this can become a sticky for future reference mods?
Jerry7297 01-24-2017 11:22 AM
Awesome Idea. Where was this 2 years ago. LOL Good job.
BurnedRubber 01-24-2017 11:43 AM
Thank you! hopefully those that haven't already done the bushings will see this.
