Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (https://www.camaro5.com/forums/index.php)
-   V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) (https://www.camaro5.com/forums/forumdisplay.php?f=76)
-   -   TR6060 to 6l90E swap (https://www.camaro5.com/forums/showthread.php?t=510414)
4SFED6.0 10-11-2017 09:03 AM
Im starting to gather parts to do a tr6060 to 6l90e swap in my 2011 SS. Dont even say that I should be going with a 4l80e, I have another car with a 4l80e and its a great trans but its not what im looking for with this car. So far i have a complete dash/bcm harness, steering column/wheel with paddle shifters, brake pedal, floor shifter and a zl1 driveshaft. I still need a new engine harness for an auto car,cooler/lines, the zl1 trans itself and a zl1 crossmember. It should be a pretty straight forward plug and play swap for the most part. I found someone that can do a reflash on the bcm and IPC to an auto calibration. Im hoping to find a trans soon and actually get started within the next month or so.
Ponykiller511 10-29-2017 02:58 PM
I’m intersested in your swap. I have a 6l90 and was thinking of a TR6060 or 4l80. I’m pushing the limits of mine. What are your power numbers and what build are you using on the 6l90? What do you plan on doing with your old parts. I would like to stay with the 6L90 but the transmissions are so touchy at high power levels. Was the TR6060 Holding up?
4SFED6.0 10-29-2017 07:21 PM
Originally Posted by Ponykiller511 (Post 9956586)
Iím intersested in your swap. I have a 6l90 and was thinking of a TR6060 or 4l80. Iím pushing the limits of mine. What are your power numbers and what build are you using on the 6l90? What do you plan on doing with your old parts. I would like to stay with the 6L90 but the transmissions are so touchy at high power levels. Was the TR6060 Holding up?
Right now I'm about 700 whp but will be a little more next year, The 6060 is working great with no issues, actually still on the stock clutch going on almost 3 years at this power level. I think The car will be more fun and definetly faster with an auto. I will be selling all of the manual parts as soon as I get them removed within the next couple weeks.
Ponykiller511 11-15-2017 12:23 PM
Any idea what you will want? Pedals, harness, slave, booster ect...
4SFED6.0 11-16-2017 06:50 AM
Ill have to figure it out and let you know,I wont have that stuff off for a few weeks yet.
bayarea408 11-16-2017 04:03 PM
where do yall source real ZL1 6l90's and avoid truck reman's. All the official GM stuff i run into is refurbished truck stuff.
4SFED6.0 11-17-2017 07:03 AM
I bought one from LKQ with 11k miles on it.
Ponykiller511 11-24-2017 12:15 PM
GM has the ZL1 6L90. Or you can change the output shaft
bayarea408 11-27-2017 12:29 PM
thank you sir :headbang:
