christianchevell |
07-08-2017 10:18 AM |
Most ramping on a roller camshaft is much wider than a flat tappet cam helping out the roller, what they call high lift is more inline with the stock camshaft in the ls engine in its specs as far as lift though the stock bumpstick has a lot of LSA and low duration I would just like to point out. They also don't go into adding advance into the LSA or other important things to consider, but they are good at doing a comparison. Choosing a milder cam for the street myself is a choice I made until I have money for other supporting mods as yes Money matters, better anything can so much add costs.
As far as the lifts most use for a mild LS camshaft the .600 and just under area for intake and lessor for the exhaust for lift along with longer duration for the exhaust to clear out the gases is the case for a good daily driving cam shaft as far as torque curve and the engine vacuum but comparatively many will not notice much difference IMO in the drivability with a larger cam unless its much larger...
much larger as most LSA are pretty close in cams, their duration was Huge in the test more inline with a stroker cam shaft for the "larger" cam even beyond what Tick calls the Polluter cam and I believe the duration to be in excess for the lift often a thing people do for a tight LSA to get a more healthy flow and more exhaust sound with the lope.
I daily drive my car, I wanted low end grunt and went milder than my last cam with its more duration and higher lift and tight LSA. I did stroke it though and the low end torque makes all the difference in the world where I drive on the street and its easier on the valve train. The difference in driving feel though from a 235/239 .629/.623 112 lsa to a now 228 / 234 .613/.578 114+4 is damn near not felt....IMO But not just reaching for the high end HP I desire more friendly until I can afford better as in intake; airforce , maybe ls7 small bore heads for the intake also a must and a 102 other than that I will stay with the stock CNC ported because its cheaper by far and may just have to be with a fast intake for the results costs so much more.... but either way I go the cam will be a stroker cam that can use the much larger duration in a way to get the flow into the larger chamber made by stroking without going insane on lift and spring pressure and I imagine it will sound even healthier and of course the numbers will rise but shifting all the power to the top end.....Not Really that useful for the daily driver /street strip car, and as that tests shows .....the torque did not change that much and that's what moves you in a heavy Chevy.
Just my rambling, have a nice day good clip Bo. And yes I will take having higher torque than my HP any day..LOL Its totally a different beast with a stroking versus just camming the heck out of it.
