Aeroforce scangauge read flex fuel sensor E%
Will the gauge read gm flex fuel sensor and show ethanol percentage?
Added gm flex fuel setup and Jannetty tuned for ethanol |
They can display alcohol percentage. I do not know if you have to use "their" sensor or if it can be any sensor. I suspect any sensor since it reads from the OBDII port.
Older versions of the gauge can be sent in to have the feature added. I do not know when they started adding the ability but in 2014, they were talking about coming out with it on their forum. |
