Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (https://www.camaro5.com/forums/index.php)
-   Camaro ZL1 Forum - ZL1 Specific Topics (https://www.camaro5.com/forums/forumdisplay.php?f=85)
-   -   Shocks please help (https://www.camaro5.com/forums/showthread.php?t=572441)
Valdizo 03-25-2020 04:02 PM
Shocks please help
So I took my car in told them to check my shock they said al 4 are leaking so have extended warranty they are not wanting to replace with oem they wanna go after market (wtf) yes I know so tell me if I'm wrong I have a 2012 zl1 and the guy at the dealer is telling me only the front came with magnetic not the back...... this sound like bs to me .... does anyone know if 2012s only have magnetic shocks in the front not back
ZMEnow 03-25-2020 04:06 PM
Run, but run quickly. There is a difference between the coupe and the Vert, but both Mag shocks. The Coupes are all FE5. Besides if they did cheap you out and replace with a non mag shock you would throw a code on the DIC because you need to terminate the 5Volts to the shock harness.
Valdizo 03-25-2020 05:16 PM
Thanks they just called and confirmed
APR_ZL1 03-25-2020 06:07 PM
Also, if they replace with a non mag ride shock, the car throw a code that will limit the speed of the car to 85mph. Found that out on a track day after switching to coilovers.
Valdizo 03-25-2020 11:53 PM
Thanks guys for your help
LevonH 03-26-2020 01:37 AM
What extended warranty do you have that covers the shocks?
Juiced1 04-02-2020 09:18 AM
They are expensive for sure. If you need a set we can get you a better deal then the dealer on a set of 4 oem shocks.
ZMEnow 04-02-2020 10:33 AM
Remember if you buy OEM verify the dealer you purchase from is covered under Delco's limited lifetime replacement as everyone isn't and those that aren't cant do a return claim. I have replace the rears twice under this warranty.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
