Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (https://www.camaro5.com/forums/index.php)
-   Camaro ZL1 Forum - ZL1 Specific Topics (https://www.camaro5.com/forums/forumdisplay.php?f=85)
-   -   Factory intercooler pump question (https://www.camaro5.com/forums/showthread.php?t=572460)
leemozoid 03-25-2020 07:58 PM
Has anyone ever seen a pump that has come loose from the mounting bracket while the bracket is still attached to the cross member and the rubber dampener around the pump is still fully intact? I was installing my repaired expansion tank today and as I was attaching the hose to the pump it seemed very loose. It was half out of the bracket, which I believe is part of the original pump assembly.
I'm going to replace the pump since I see no way to replace the bracket onto the pump. Is an OEM pump sufficient or is aftermarket preferred?
Juiced1 03-26-2020 08:40 AM
You should be able to bolt it back down unless the bracket itself broke. The oem pump is decent on the ZL1. I believe it's an upgrade for the CTSV guys.
ZMEnow 03-26-2020 09:09 AM
Sponsored by: ZL1, CTSV, ZR1 and other intercooler pump flow test results
The ZL1 pump is very good.
https://www.corvetteforum.com/forums...t-results.html
leemozoid 03-26-2020 11:22 AM
I see no way to get the bracket back on the pump without taking either the bracket or pump apart. Both appear to have been manufactured as a complete assembly. I think I'm just going to replace the old pump with a new OEM. Thanks for the replies.
Steven
Vicster 03-26-2020 09:13 PM
PICS
Steven
Pictures would be a great help to see what you are dealing with.
LevonH 03-26-2020 10:48 PM
Looks like the bracket simply expands to go around the pump???
https://static.summitracing.com/glob....jpg?rep=False
https://www.camaro5.com/forums/attac...1&d=1340803782
And this Thread has good info:
https://www.camaro5.com/forums/showthread.php?t=255716
ZMEnow 03-26-2020 10:51 PM
Steven
That pump is is in a very protected place not sure how something could get at it to break the bracket, assuming the lower arrow cover is on, or you have never broken a SERP or SC belt. I once broke my tensioner on the SC and it let go at the light. Had I been in it the bracket probably would have come through the hood.
leemozoid 03-31-2020 08:07 PM
Bottom line was that nothing was broken. The crossmember mount was in place and intact. The ring that surrounded the pump was intact and unbroken as was the rubber dampener. The manner in which the pump was able to become loosened from that ring is unknown. So, I replaced the whole assembly.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
