radiator overflow tank
???? 2010 v6 overflow tank has a hose running from rad cap into the fill tube
near dip stick. does the hose stop just inside the fill tube??? or should there be another hose running down inside the tube to the bottom of res tank?? thanx turtlezx |
can someone please look??????????????????
I just looked, and it appears that the hose extends down into the overflow tube. I couldn't see how far, though, and I don't have a diagram, but I can clearly see that it doesn't cut off at the container.
thats what i fugured it did no way to draw coolant back to rad when cools off
without it .Must have fallen into tank or never had i since new thanx will make i up |
my mistake hose is in the lower 1/2 couldnt see it with out flashlight
Its behind a step in the tube blocking view iam good now thanx turtlezx |
