Tuning the BMR complete ZL1 rear suspension with Strange shocks
At 60k my magride shocks were leaking to the point of replacement. I decided to do a complete rear suspension replacement. Now comes the hard part. Tuning the shocks so my car (a 2013 convertible ZL1) doesn't ride like a Conestoga wagon. With compression at 3 and extension at 5 she still has her ass in the air like a cheap whore but only the roughest of pavements bounce my head off of the top. What experiences have you who run these suspensions had with tuning these shocks? What settings work best for you?
:pop2:
Was the suspension torqued with a loaded suspension? |
This is the first time i heard of this !! Bmr installation instructions doesn’t say anything about that??? Or do you mean to say timing the bushing |
Can an expert chime in here? |
Nobody ever tuned one of these? I'm getting fair ride quality on the street but needs some tweaking. I can see "-" and "+" on compression but not on extension. She's still bouncy on the major dips but the seams are smooth. More compression or less? There seems to be 10 adjustment stops on extension. Which direction is "0" and which setting is best for street/strip car.
[] more compression [] less compresson [] more extension [] less extension Help a brother out! I don't want to shake my baby to death with all this new power and a wonky suspension. |
Looking at this kit....I still wonder if clocking/timing the suspension would be the first step. Then try adjusting to you liking. Im only guessing the springs are stock height (BMR doesn't indicate).
start by lowering your compression, if your at the last increment and it’s still harsh you need a softer spring. maximize your rebound a couple clicks, it could be set too fast which will also give you a harsh feel.
Edit: a break in period is required but it shouldn’t be as stiff as ur explaining. possibly they are torqued down too tight not allowing movement in the pivots? too much spring preload? |
