Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (https://www.camaro5.com/forums/index.php)
-   Mechanical Maintenance: Break-in / Oil & Fluids / Servicing (https://www.camaro5.com/forums/forumdisplay.php?f=65)
-   -   2010 Camaro SS GM fluid specs and part numbers (https://www.camaro5.com/forums/showthread.php?t=309927)
freedomintheskies 07-29-2013 08:40 AM
I was at the GM dealer this morning to pick up a bottle of limited slip differential additive and the parts guy was kind enough to print me out a list of GM specified fluids. I figured I would post it here so that others can use it as a quick reference.Cheerz!http://www.camaro5.com/forums/pictur...ctureid=108419
freedomintheskies 07-29-2013 08:46 AM
Oh, the AC Delco Limited Slip Differential Lubricant Additive P/N is 992694 (114ml) and like all other fluids, they reccomend you warm the vehicle up before draining the differential. This gets any contaminants into suspension, so that they can be flushed away when draining.
freedomintheskies 07-29-2013 09:11 AM
And a link to the AC Delco site for maintenance parts...http://www.acdelco.com/parts/#fullParts
