Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com (https://www.camaro5.com/forums/index.php)
-   Camaro DIY & HOW-TO instructions & discussions (https://www.camaro5.com/forums/forumdisplay.php?f=67)
-   -   How can i remove the side mirror glass? (https://www.camaro5.com/forums/showthread.php?t=562399)
imponte 09-21-2019 04:04 AM
Hi guys. How can i remove the glass? Can i just pull the glass out? Or there is something else?
fhrex 09-23-2019 05:27 AM
https://www.camaro5.com/forums/pictu...ctureid=163350
1
Outside Rearview Mirror Glass Retainers (Qty :6)
Warning: Refer to Glass and Sheet Metal Handling Warning.
Procedure
Apply several layers of masking tape to the top of the outside rearview mirror housing in order to protect the painted finish.
Push the mirror glass (2) inward at the bottom of the mirror glass until full travel is reached.
Insert a suitable tool behind the mirror glass and housing, pry outward until the mirror glass is releases from the retainers.
Disconnect electrical connectors from mirror, if equipped.
2
Procedure
Align the mirror glass retainers with the retaining tabs (1) on the actuator.
Using a 9 cm (3 in) rubber sanding block placed in the center of the mirror glass, apply pressure until an audible click is heard.
Inspect the power mirror for proper operation.
frankwjr 09-23-2019 08:43 AM
1
Procedure
2
Procedure
Tks bro.....happened to be lookin fer dis info too!
l8tr
PEACE
imponte 09-30-2019 08:01 AM
1
Procedure
2
Procedure
Thanks. This is helpful
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
