2016 camaro rs v6 spark plug swap
Hello all, quick question. on a 2016 camaro v6, do you need to remove the intake manifold to get to the spark plugs ? I quickly glanced at engine bay and thats what it looks like?
Bump tried the :search:
When I checked my plugs a while back (I indexed them actually) the only practical way I could find to access them was to remove the intake manifold.
That allows the sound padding to be removed without damaging it. Also it allowed me to identify and correct some air leaks at the intake gaskets. So it was a good thing. It is really not all that difficult to do because there are no liquids running through the manifold. Just be very careful not to drop anything into the intake ports of course. I stuffed paper towels into them as temporary plugs. |
But then I would have heard more of the valve train and high pressure injection pump noises. Personally I prefer not to listen to them so I put the padding back and have even added additional padding under the cosmetic cover over the manifold. Now I barely hear the high pressure pump at all. For all the more often that most people will need to access the plugs it really is not much of a problem to remove the manifold. And you can check how carboned up your valves are at the same time. It most definitely is a matter of personal preference with benefits both ways. :D |
