JRE no tune 10% pulley (Dyno results)
2 Attachment(s)
Bone stock my 2012 M6 ZL1 made 500rwhp. With just an upgraded HX and coolant pump and Metco 8.6 inch crank pulley.
552rwhp!!! A/F ratio looked good the entire run. The first run there was 3 degrees of knock retard at 4600 rpm. The second run was clean. http://m.youtube.com/watch?v=vdtx23OA71M# |
Nice results, what octane?
What was your base torque?
Wow that puts you at around 640 HP @ the crank. :w00t:
looking good!
Nice numbers. I bought Roto-Fab/JRE no-tune 75 rwhp kit.
Base torque was 491. |
(pre-ignition) was sensed at 4600 rpm and backed off the timing by 3 degrees. From 21 degrees advance, to 18 degrees advance. HX = heat exchanger. Pump and hx are from Coolerlogic. |
Everything is computer controlled nowadays. :)
WOW, that's near 2 grand worth of upgrades. :yikes:hmmmm
Only 20 shy of the GT 500! Nice! |
awesome numbers
