RobRiot88 |
08-27-2013 08:27 PM |
FS Nitrous Outlet 90mm 2010+ Camaro Plate System + Goodies
6 Attachment(s)
This is the most effective kit on the market for your 5th gen Camaro.I had bought everything brand new. It has never been sprayed. I installed it in time to receive a free turbo kit.(self explanatory) Uninstalled this kit. It was never powered or completely wired. You get 95% of everything you'll need to run this kit. Including wires and plumbing, Instructions, nitrous pills, TPS connector harness, relay, NOS RPM/WOT window switch, bottle brackets, Nitrous outlet 10lb Bottle(full unless UPS catches me) with Glow in the dark pressure gauge, Zex automatic bottle heater, Nitrous Outlet 2010 Camaro cup holder switch panel, Nitrous Outlet Fuel/Nitrous/Purge solenoids and brackets, steel braided line, everything but the throttle body bolts(hardware kit is $25 from nitrous outlet and will fit either the stock TB or the Nick Williams TB) and maybe a couple wires and some electrical tape. MSRP i believe was around 1300+, asking 1000 for everything. If you have any questions feel free to ask. PM if your interested
