BUMBLE-B-TUNA |
06-27-2014 06:30 PM |
Audio Frustration Grrrrr
I need some advice on what to do with my stereo system. I have a 2010 SS with the ******** FARK harness, JL 500 amp running two 10" subs and a JL XD 400 running JL components up front and JL 6x9's in the back. Sounds pretty good but I wanted to add an equalizer to fine tune the system. Tried the LCQ-1 from Audio Control and although it worked ok, I needed to crank the gain on my amps to get any volume, this brought in the alternator whine. I guess its designed for higher output from the factory amp ( which I turfed).
I would like to find a way to get a higher output into the LCQ-1 if this is at all possible, I may need the stock amp to do this ??? I don't really want to go with an aftermarket HU because you need a Schoche unit to keep the factory controls and that's $$ I don't want to spend. I think I'm almost where I want to be if its actually possible to do.
If some Guru out there has the answer I sure would appreciate it.
