Oil Pan TSB
Hey guys, Can someone refresh my memory on a TSB related to the oil pan on LT1 motors? I seem to recall something about this but do not remember the details. My motor is currently out of the car so it's a perfect time to check my pan.
there was something to do with the steering box bolt. not sure about an oil pan. I think during the first runs there was a pick up tube or something, but wasn't very many I believe. I could be wrong.
I believe it was oil cooler lines.
There was a bulletin about the bolts holding the pickup tube in the pan. If I remember correctly if your pan had raised numbering it was faulty but if the number was stamped in you were fine.
