Did cradle bushing inserts and trailing arms.
So I have a 15 camaro 1le with a btr cam, headers and intake. Had some wheel hop and decided to do the cradle bushing inserts and bmr trailing arms to minimize it. Now I think its actually worse. I get a loud bang when shifting gears like the whole cradle is moving but everything is tight. Any ideas? Should I have gone with the full bushings not the inserts?
How hard was the bushing install
Sent from my SM-N950U using Tapatalk |
Do bmr lca too
sounds like something is loose
That's very strange indeed. The ZL1/1LE/Z28 cradle bushings are much better than the SS/V6 stuff to begin with, but inserts should still be an improvement. Stuff banging around definitely points to something still being loose - neither of those mods should cause banging.
there are 3 items you need to get rid of Wheel Hop - Trailing Arms, Toe Rods & Cradle Bushings. to the OP, the Full Bushings are probably what you need
Is there a write upon diy bushings
https://www.camaro5.com/forums/showt...t=cradle+torch |
Thxs, regular ploy bushings or offset bushings
Couple good videos on YouTube for the bushings. Did you remove the exhaust when you did your work?
The install wasnt too bad. I thought the 1le had upgraded toe rods.
As far as the bang goes I'm not sure what's causing it. Maybe a single hop on the tires. Just seems loose in the back now.
I did pfadt solid subframe bushings, pfadt trailing arms and pfadt toe links. Only time I get that one hard bang is on the strip doing a 1st to 2nd shift. It's slop in the driveline and shocking it getting back into power. You might want to go over everything again because I would never describe the back end of my car as loose. Those mods made a huge improvement over stock. |
1 Attachment(s)
I installed inserts many years ago and it did nothing but improve the stability. I rarely have wheel hop now.
Did you use new bolts? Are they torqued correctly? |
