Boston Acoustics speakers in a 1LS
Has anyone tried this mod yet? I was looking into getting the 9 speaker BA set for my wifes 1LS but noticed that the rear deck speakers on the BA system have a 4 pin connector and the factory setup has only 2 pins in the connector.
What i was wondering is if the BA setup can be installed in the car with an adapter (if one is even made to accomodate the BA speaker)? I haven't checked any of the other speakers to see if the pin connectors match up or not, but i did notice that the center dash speaker would not work because the 1LS dash was built without a center dash grille that can be removed like on the other models. The indentation is there, but no grille. Thanks for any input.:iono: |
also if i wanted to get the HUD displace unit same deal or no?:iono: |
you can find better speakers then those for cheaper
I wasn't very impressed with the BA sound system compared to the stock sound system. If you're going to go through the trouble of modifying it, go elsewhere. Much better stuff than BA.
I have the BA speakers and honestly if these are "premium" speakers, I don't know what are crap speaker. My VW has better speakers than this from the factory. Definately not worth the 600 bucks that they charge for it. For that price I could get some decent Kickers.
the BA are clear.. just not much bass.. needed a set of subs.
the BA counts the rear deck as 4 speakers, not just two. So without modding, no you couldn't get the 9 in your car. just 8 |
I'm going to check the door speakers and tweeter in a couple of days to see if they will fit up to the BA speakers. Iv'e got a 1SS as well as a 1LS so i can see if they retrofit. I'll re-post with the results.
Parts of the dash trim unclip to gain visibility to the center dash speaker area. I'll check if the car is pre- wired for that speaker also. |
O.K. I took the tweeters out of my wifes 1LS and my 1SS and compared the 2. Just so happens that they are the same identical tweeter? WTF? Same GM part # and everything. I thought if you had the Bosyon Acoustics system the tweeters would be the BA type, not the bone stock tweeters. I thought this was supposed to be a 9 speaker BA system? 2 tweeters, 2 door speakers 1 center dash speaker and 2 rear deck speakers / with subs built in. That makes 9. Well looks like GM screwed everyone on the tweeters cause they sure are'nt BA.
It started to rain when i was going to check the door speakers for fitment so i will check them in a couple of days. |
