MartinLe |
11-25-2020 09:52 PM |
Originally Posted by UnknownJinX
(Post 10908893)
I don't think it's normal for it to grind. It might be a little notchy when cold, but I would say that grinding doesn't sound normal.
At the same time, if your transmission works fine when warmed up, I wouldn't worry about the synchro grenading itself at high RPM.
Notchy - I'm not sure what that means. The grind I'm referring to is kinda like a six tooth grind, if that makes sense. It doesn't fight me, it just makes a little noise that wasn't there in the summer.
Originally Posted by Crusher Camaro
(Post 10908902)
wouldn't call it the smoothest, i do not have to fight it, but it doesn't grind either.
Maybe what you are referring to is the "Notchiness" the above poster is talking about? When I put it in third, I don't fight it neither, but I can still feel it go in, if that makes sense. During the summer, when I hotfoot it through the gears, I feel nothing in the stick.
Originally Posted by SquirrelyZL1
(Post 10908923)
Do you notice any clutch slip? This can be a result of faulty throw out bearing or even a wearing clutch. It’s a bit far fetched, but definitely a possibility.
I am sure the clutch is in fine shape.
