Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Wiki
DIY: SIDE GILL FADE AND OUTLINE INSTALL
(first draft pics and links coming)
Wet install.
Fades first, then outlines. Really difficult to line everything up, but it was worth the effort.
Instructions:
1. Clean hands and gills with alcohol and a lint free cotton towel.
2. Let dry COMPLETELY.
3. Spray install lube spray on gills. Don't be shy with the spray.
4. Install 1st fade from the top down, using your finger as a squeegee. If it's off a little, you can SLOWLY slide it into place.
5. Repeat steps 3,4 until all fades are installed.
6. Let dey 30 min or so in the sun.
7. Repeat steps 2,3,4,5 using Stripeman's outlines. Be CAREFUL. They're fragile!
8. After an hour, mist with water and wipe off excess lube. The lube is just 4 drops of Dawn in a cup of water, so it won't hurt anything.
After they are on about a week, you can wash and wax after you check for lifting.
Enjoy the look!
Created by Milk 1027, 10-14-2009 at 03:55 PM
Last comment by Duflar on 09-08-2010 at 09:59 AM
2 Comments, 10,873 Views
You may not create new articles
You may not edit articles
You may not protect articles
You may not post comments
You may not edit your comments
