Oil Change at 881miles??
Hi everyone. I just picked up a 2013 SS with the Ls3 motor. It was a used, yes I said used, vehicle and was garage kept by an older gentlemen for a little over a year and barley made it out of his driveway while owning it. So my question is, with all that sitting time should I change the oil ? And would you consider it still in the "Brake in" period? Thank in advance.
I would change it.
agreed.. change it.
Change it and yes you are still in the break in period.
Thanks for the replys. I'll be changing it tomorrow.
1 Attachment(s)
You might want to consider adding a magnetic drain plug. My 1st oil change was at 36 miles and this is what it collected in 582 miles.
+1 Change it at least once a year if it doesn't get driven that much.
Any time I acquire any used vehicle, I change all the fluids. The only time I would not is if it came from a dealer I trusted that had done that when they took it in already.
