afm / dod delete kit questions
Hey guys I was hoping that some of you could help me with a afm / dod delete kit questions. I was wondering if anyone knows if this kit from AMS https://www.amsracing.net/collection...-bolts-lifters
is a good kit and about how much horsepower it makes? Or the stage 2? Is there a better one out there that supplies the tune? Also was thinking of doing a trunnion kit for the rockers if you guys think that I should. I just was hoping for around 400 hp to the wheel. I don't even know if that's possible with a cam change. I'm also looking for some coated long tubes and full exhaust kit. I'm sorry for all the questions in one thread. I appreciate any help. Thanks Joe |
You can easily get mid 400’s with a cam and long tubes with tune. Maybe get in contact with the guys over at complete street performance or rdp or gpi and they can get you quality kit and remote tune setup.
Unless your car has very low miles I would recommend replacing the oil pump and the timing chain. If you have the $$ I woukd get the heads ported also. They are going to have to come off anyway. As far as HP I would not get hung up on the numbers with an L99. You can put the same upgrades on a LS3 and they are always going to beat you on the dyno. But on the track where it counts is a different story. With that said L99 bone stock your probably looking at 326-340 whp. I'm not familiar with that kit but I would say 400whp is probably a stretch without any other mods. Again it's just a number when it comes to the L99. You will find that most guys go with GPI or TSP I would at least take a look there before making a decision. If your looking for long tubes take a look at TSP if your on a budget look at speed engineering. I have the epeed engineering and have been pretty happy so far.
If a number is your goal download TrackAddict on your phone or take your car to the strip. Focus on 8th and 1/4 mi. Times. Sent from my SM-F916U using Tapatalk |
I'm on a budget of about $2000. And I guess I'm going to do the work myself even though I'm not in a hurry. |
What do you guys recommend for the rockers. Can I leave them alone or do I need to do the trunnion upgrade?
Thanks guys for your input.
Yeah I would trunnions and oil pump for sure. I also did oil cooler delete with mine to prevent any future leaks. You could do long tubes and cam only and be at 430 wheel with the stock converter.
Oil cooler shouldnt be a clearance issue with the long tubes. My installer/tuner did the delete just because of that drip reason.
The oil cooler didn't get in my way with the long tubes but I removed it anyway as a precaution and it would have been in my way later with my mods. But no issue with long tubes.
Also I reccomend GPI for this. (Dod delete, ss3 cam, trunion upgrade, springs, push rods, timing chain, tensioner, oil pump, 25% ud pully, heads, long tubes, cats delete, xpipe, muffler delete, stall, cai intake, rod mod and tbody netted me 426 rwhp before I turbocharged it) |
