Help with bmr springs
2 Attachment(s)
What's going on guys I put my front name springs and when I lower the car this what I got
If you're worried about the top of the struts sticking out above the strut towers, that is normal :thumb:
Apparently that seems normal based on searching on the forums.. even BMR confirmed it.
http://www.camaro5.com/forums/showthread.php?t=506161 Although I don't recall mine looking like that.. unless I am blind. |
The Passenger side is lower then the driver side if i lift it off the floor it go back to normal
Turn the wheel while the car is on the ground and look how they move. Lol. It was driving me crazy at first then I found out it was normal.
I did lol I just don't like how it's look
If they're an uneven height left to right, know that you have to "time" the suspension bushings after changing ride height. There are various guides on this forum that explain how to do so, what it all means, why you need to do it, etc.
it is normal to have a Gap as the Strut assembly needs to rotate. It was there before, you just didn't realize it. If the Gap is Too big, then you need new Strut Bushings
:iono:The car only have 26k so I don't think I need bushings
How about you get back to us after you get everything properly reset. :thumb:
It may be a bad strut, worst case. If you did the work yourself, you may want to go back and remove the one that’s sticking up. Verify everything is on correctly. That’s what I would do.
Sent from my iPad using Tapatalk |
Last night I removed the driver side recheck everything put it back in and its the same
Stock struts? Sent from my iPad using Tapatalk |
BMR is right. I had the same "issue" called them and they said it was there before, I just didn't notice it. No problems since the install. Nothing to worry about!
