#43 |
Romanian Outlaw
Drives: 13 ZL1 , 14 Silverado Crew Cab Join Date: Apr 2010
That thing is to sick!!
[/SIGPIC]
#44 |
![]() Drives: 2011 GT500 Join Date: Apr 2012
I got an adrenaline rush just reading this, I can't imagine being in the driver's seat. Fantastic write up and some truly spectacular driving.
#45 | |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
I will state that a video taken from inside the car shows the windshield getting wet almost immediately after the head gasket let loose, which means water from between the head and block made its way up and through the vents and/or under the back of the hood at speed. I don't know if any made it down under the car...The water on the windshield tells me there was a lot of air being forced out the top from pretty low down in the engine bay. I didn't notice any hood fluttering at speed either. which I've seen at speed before the hood vents... We skinned the underside of the car from the front bumper cover back to the bell housing to keep air from under the car. We also removed the rubber strip at the back of the hood underside along the firewall. All of these are things we did to improve the down force of the car... We certainly don't have access to an air tunnel so the degree of improvement isn't known... but... My seat of the pants feeling is the car is incredibly stable even over 200 mph. It never felt lite at all, just planted and firm. I did remove my dove tail spoiler from the rear deck lid and re-installed my factory lip spoiler. This was due to 1. the wind resistance the blade would create, and 2. the fact that no one at GM could/would tell me how much down force they create and would it actually rip the spoiler off at speed. That would be brutal... a couple thousand lbs of down force suddenly gone and the suspension unloading at speed... As for running that fast before, I had been about 175 in this car, and it felt good but not as well planted as it did with the changes we've made..
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
#46 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
That sounds like so much fun, and that was a good save man! I see stock rims, you still running stock tires? I guess it would be tough to keep traction with any width tire with the turbos and nitrous.
#47 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Looks like quite the experience.
That's putting a lot of faith in stock wheels and tires though. I'd stick some forged racing wheels on that thing for those kind of speeds. Cast OE stuff at those speeds would not be for me. I've seen more than one car of various makes at those type of speed events blow a wheel to smitherenes and send the car tumbling. Maybe some ZL1 wheels would be a nice setup for a top speed effort Camaro. |
#48 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
Can't believe I just saw this Robert! Wow 190 run is outstanding! That burnout video is wicked! Can't wait to see what you can pull off the next time you go!
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
#49 | |||
Boosted Moderator
#50 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
![]() Out of curiousity, what kind of head gaskets & bolts/studs were you running? I'm always wondering just how much boost these engines can take. I know I felt alot more comfortable after upgrading the head gaskets and going all out ARP studs. Stuff happens, but doesn't stop the fun..... just comes with the territory ![]() As for wheels/tires.... I've noticed a Huge difference between running my OEM rims and Forgeline's or Weld's after all the suspension upgrades and near solid engine mounts - nothing like having a precision wheel. When I change from my NT05's on all 4 corners to the Pirellis it's like the difference between snow tires and bald summer tires in the winter. I'm only happy on my Nitto's..... feel like I can actually use the throttle without constantly spinning. Is there a particular tire recommended for traction AND high speed for the Texas Mile?
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
