#281 | |
Drives: 2010 Camaro Join Date: Jun 2009
Thank you for the feedback, and I am glad to hear your happy with the AIRAID. Thanks, David |
#282 |
SoCAL Camaro Owner!
I've been reading and lurking around these forums for months and I finally got the courage to buy this intake kit! Should be in by Friday! I will be doing the installation by myself but after reading about what others went through I think I'm well prepared.
#283 |
![]() Drives: 2010 Camaro 2LT RS Join Date: Jan 2010
Just curious, if you don't disconnect the battery or pull the fuses, will the ECU eventually catch on and adjust to the new intake?
#284 | ||
Sounds great. Let us know how it turns out. If you have any questions at all, do not hesitate to ask ![]() Quote:
The battery disconnect on the 3.6L V6 is more for a safety issue. No need to pull the fuses as the computer will adjust to the new parameters on its own. Thanks, David |
#285 |
Ruby & Blu Imp
Drives: 2010 LS3 2SSRS M6 & LLT RS A6 Join Date: Dec 2009
Couple of feedback points for the d-i-y crowd ( I am no expert but made a few observations and figured I'd post so others have it easier):
1. A little soapy water for lubrication and a flat blade screwdriver to open up the gap for the rubber weatherstrip help tremendously. I held it in my lap and applied pressure to the top of the weatherstrip prior to installing the body into the engine bay. Figured out about halfway through that a little lube would make it a much easier job. A small amount of soapy water wipes off and dries out well. 2. When you are putting the screw and lock washer into the spacer/brace for the negative post/ground relocation, to reach the bolt stand on the driver's side facing forward and use your right hand to turn the bolt. The angle makes it a lot easier to hold the pieces and turn the bolt inside the bracket. 3. Apply a little chalk on the top of the weatherstripping to show where it makes contact on the hood liner. Looks like a light contact helps insulate out the hotter engine bay air. 4. When popping out the "re-used" stock air inlet tube it is easy to pop out the wide side on the top first then the sides; also easy to pop it back into the new housing small side down. 5. I would have insulated the MAF sensor had I thought about it if I was not disconnecting the battery. BTW - I will always disconnect the battery as my prior luck with a fried ECU (Land Cruiser) taught me the hard way. Again this is just my $0.02. Hope it helps.
Ruby
2SSRS M6 - Blown & LLT RS A6 |
#286 | |
13.453 @ 101.90
Drives: 2010 Camaro 2LT Rally Yellow Join Date: May 2009
#287 |
SoCal C5 Family Member
Drives: 2010 CGM RS Join Date: Aug 2009
How long did it take others to get their Airaid when ordered from magnaflowplus?
#288 |
Don't Feed the Troll
Drives: 2010 Camaro 2LT/RS & 1999 Corvette Join Date: Jun 2009
I think mine took about 3 or 4 business days. Just depends on where you are located I would guess. If you don't see it in 5 business days I'd give them a call to track it.
#289 |
Ruby & Blu Imp
I just put the battery cable in a leather glove...low tech...
Ruby
#290 |
13.453 @ 101.90
#291 | |
![]() Drives: 2012 CTS-V Coupe & 2SS/RS Join Date: May 2009
Mine took the following day to get !!
#292 |
SoCAL Camaro Owner!
I got my air intake on Friday and I installed it Saturday morning. The installation took me about 2 hours with a partner. I have seriously almost zero knowledge about cars and I found that the instructions were easy to follow and I ran into no problems. The power increase is amazing and I love the sound. I would post pics but it has been raining the past week so I'll wait until next week.
I did not get a CEL reading or whatever the error message is. I didn't unplug my battery or fuses and I left all my doors closed throughout the whole installation. I turned on the car and it worked perfect. Thanks for a great product. |
#293 |
I got my airaid today and when I looked at the box it had a sticker on it saying for "off highway" use only. Has anyone elses come with this and will the dealership still install it?
#294 | ||
Thank you for the positive feedback. I am happy to hear your pleased with the AIRAID Intake! Quote:
All the Camaro systems have that. It is a brand new product that has been released recently and not CARB legal, so we have to put that provision on the box for legality reasons. Thanks, David |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 08:33 PM |
| JDP Motorsports Airaid Intake Specials! PM for Coupon Code! | JDP Motorsports | V8 Bolt-Ons & Tunes | 13 | 12-02-2009 12:44 PM |
| Official Camaro Convertible CONCEPT Press Release | Tran | Camaro Convertible Forum | 12 | 11-18-2009 08:05 PM |
| Autoblog drives V6 Camaro w/ ground effects and GMPP wheels. Shares public reaction. | Tran | 5th Gen Camaro SS LS LT General Discussions | 1 | 07-13-2009 12:17 PM |
