#337 |
Under construction...
Drives: Black 2012 2SS Join Date: Jul 2014
It will but the cowl lines will not line up
2012 2SS/RS, mods coming soon
#338 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Now time to order the part and summon enough guts to do it lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#339 |
I searched but couldn't find the answer... Anyone install this with an OEM strut bar installed??
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
#340 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
I have it with the OEM strut bar and no issue. The 2014 hood will work however the lines on the 2014 hood do not line up with 2010-2013 bumper cover. You could do it but there will be gaps where those lines meet. We took a car from a dealership and did a good swap and it worked as far as install but didn't match up. Just enough for the OCD in this SOB to kick in and say hell to the naw!
Never grow up, it's a trap!
#341 |
'It's an experiment'
I did the hex vents with the Strut bar -- no issue -- as long as you tell them you have the bar (and you want the 'drip' pans)
-Don |
#342 |
![]() Drives: 2012 1SS/RS Join Date: Jun 2013
Yes this works fine. I have the OEM strut bat and had no issues. Its interesting to see but once you cut the hole in the hood it surprises you just how low the engine and even strut bar are under there. Tons of supercharger room I suppose.
"Driving is the only thing I love about f1."
(Kimi Raikkonen) |
#343 |
Sweet thanks... Ordered mine last night.
#344 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 1LS Join Date: Apr 2014
Glad everyone is enjoying their vent! I can't wait to do mine! I'm gunna have lethal racing do an apr splitter and z/28 spoiler with wickerbill and a mgw shift kit while it's in there! Should look and shift like a totally different car when I'm done! For those that have done the vent AND water tray is the tray easily removable? And can you actually see the vent working at stop lights?
#345 |
For mine (hex vents) -- yes, the vents work to remove heat -- my drip pans are bolted on so you can remove them easily -- the 'one piece' not sure
-Don |
#346 |
Really thinking about doing this but nervous about cutting out so much of the bracing. Have any of you experienced excessive flex in the hood after?
#347 |
Member BLACK10 has one on his car and it looks good. Hood and bumper lines don't match up but it still looks good.
#348 |
Hopefully I'll be able to get this done soon!
Patiently waiting for my 2023 SS 1LE |
#349 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I'm still working up the nerve to do this...
#350 | |
![]() ![]() ![]() Drives: 2011 RS Join Date: Apr 2011
