Old 12-11-2014, 01:04 PM   #365
crc91
crc91's Avatar
Drives: '14 1LS
Hey guys I'm putting in my order for the 2014 hood vent, fan shroud, and drip tray. Lethal racing is going to be doing my install, along with an apr splitter. I got the part number on the shroud, for the hood vent I want the 1le vent because I think it's a different color black. The one on the accessories page says it's factory matched black. Does anyone have the part number on the 1le hood vent? I believe the correct one is 22828242 I just want to be sure, also it maybe in the thread I may have over looked it but what is the drip tray part number?
Patiently waiting for my 2023 SS 1LE
crc91 is offline   Reply With Quote
Old 12-11-2014, 03:24 PM   #366
TECHTURTLE
TECHTURTLE's Avatar
Drives: 2016 Camaro 2SS
I used Extractor 22828242, Water Tray 23180572 and Shroud 22828415.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 12-24-2014, 01:31 AM   #367
crc91
crc91's Avatar
Drives: '14 1LS
I got all my parts the other day! I think the fan shroud piece I'll have to take off my catch can and disconnect my intake tube. That shouldn't be too much of a problem. My parts didn't ship with bolts or nuts or anything(except for the built in pieces). What so I need to buy to mount everything? Or do I wen need to lethal racing is doing the install and charging me a "shop fee" of 55 dollars for misc item,fluids,etc. which is fine if they can make the beakers and stuff for the tray and get everything mounted well.
Old 12-24-2014, 06:31 AM   #368
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Looking for a P/N on the 14/15 1LE Hood Liner
Old 12-24-2014, 06:33 AM   #369
TECHTURTLE
TECHTURTLE's Avatar
I was able to get my fan shroud in without removing anything. I put the driver's side down in first then the passenger side. The three snaps hold it in place with no problem.
Replace the bolts it came with, with two inch brass toilet bolts. You can pick them up at Home Depot. But before removing the orig bolts press the extractor into the rain tray. the bolts will make marks in the tray so you'll know where to drill the holes. If you can't see the marks put some painter's tape inside the tray then press down. Drill where the marks are.
Added
Old 12-24-2014, 07:44 AM   #370
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
23152819
justjoshin is offline   Reply With Quote
Old 12-24-2014, 03:18 PM   #371
crc91
crc91's Avatar
Drives: '14 1LS
I'm not the one ho's going to be installing it . Lethal racing will be. Guess I'll have to give them a call to see how they are going to be installing it and if I need to provide anythin else. So aside from the beakers I just need two brass bolts?
Old 12-24-2014, 04:31 PM   #372
TECHTURTLE
TECHTURTLE's Avatar
6.
Added
Old 12-24-2014, 04:41 PM   #373
crc91
crc91's Avatar
Drives: '14 1LS
6.
Okay so 6 brass bolts and the brackets, question why can't I use the bolts that came with the extractor? I'm not sure how one would remove them.
Old 12-24-2014, 07:46 PM   #374
justjoshin
justjoshin's Avatar
the bolts that come on it are not long enough to go through the rain tray. This is how most people are installing it as the non 2014+ SS hood doesn't have the holes for the push pins that normally hold it in place. The bolts fit in a slot on the scoop and people have replaced them with brass toilet flange bolts.
Old 12-24-2014, 08:36 PM   #375
crc91
crc91's Avatar
Drives: '14 1LS
Cool thanks for the Info man. So if the bolts hold the rain tray to the scoop would I need those brackets that some people are picking up? Sorry for the questions I just wanna get as much info as possible you've been a great help so far Tech. It looks like the bolts that come on the scoop slide out I've tried to get them out but they don't come out easily. Is there a special way to do it?
Old 12-30-2014, 08:14 AM   #376
TECHTURTLE
TECHTURTLE's Avatar
Sorry, been out of the country...
Just push, they'll come out. The toilet bolts are not as tight, so I ran a nut and washer down to hold them in place.
I didn't use the brackets, just secured it to the rain tray.. Looks a lot cleaner and it's still really secure.
Added
Old 12-30-2014, 08:55 AM   #377
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
When I installed my TL-1 extractor it came with a tube of polyurethane windshield adheasive to put a bead around the edge and glue it to the hood. If you never plan on removing the extractor I suggest doing that before bolting it down. You won't have to worry about losing it.
The Bird is the word!
Old 12-30-2014, 03:20 PM   #378
crc91
crc91's Avatar
Drives: '14 1LS
Sounds good, yeah I can't imagine ever removing the extractor. Maybe the deflector occasionally but not the extractor.
Thanks Guys I'm going to try and get it done New Year's Day. I think me and my dad are gunna try our hand at installing it. Can't be that hard!
