#533 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
🏽 🏽 🏽 🏽 🏽Sent from my iPhone using Tapatalk
Never grow up, it's a trap!
#534 |
![]() Drives: 2011 1SS Red jewel tint Join Date: Jun 2015
Just t update people. ACS is now making various kits to put the heat extractor on the 10-13 hoods for both SS and V6 models:
http://www.acscomposite.com/project/...ategory=163626 They have also have an option for just the water tray. For an extra $25 you can purchase the templates with the water tray kit. Nice option for guys who have the heat extractor already. http://www.acscomposite.com/project/...ategory=163626 I ordered the water tray with templates and will post again once I install it. 'Moe |
#535 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I feel that if I do this with the vararam intake the vent won't see as much air flow since some of the vent will be blocked. Am I right on this or does the vent sit back enough to not have the intake block air flow?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#536 |
The purpose of the vent is to extract heat out from the motor. While the Vararam has its ducts for airflow in front of the radiator, there is air coming into the motor from the grill area itself which will make its way around that VR duct as well as over to push air out the top. That's what it's all about. I have a radiator cover in that same area and I see the heat waves pouring out.
![]() Sent from my iPhone using Tapatalk
#537 | |
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 Last edited by xc_SS/RS; 08-03-2015 at 11:35 PM. |
#538 |
I've lit a fuse or flare and placed in front of the car with a fan going to see where the smoke exits. I have it coming out the hood vent as well as my 3d Carbon side fender vents. There's enough air coming thru to move it up and out I would say.
#539 |
I'm curious how much air flow will happen with the water tray in place
Sent from my VK810 4G using Tapatalk |
#540 | |
#541 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 1LS Join Date: Apr 2014
+1
Patiently waiting for my 2023 SS 1LE |
#542 |
![]() Drives: 2013 camaro Join Date: Mar 2013
What size toilet bolts are people using for those that used that setup?
#543 |
I went to HD to get the toilet bolts but they don't snap into place as everyone mentioned.. And ideas to have them sit and stay?
#544 | |
![]() ![]() ![]() Drives: 2011 RS Join Date: Apr 2011
#545 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I think those are the wrong bolts, they should have a oblong head on them and not round. I think that you have the toilet seat bolts and not the ones that mount the toilet to the floor flange.
The Bird is the word! |
#546 |
Ahhh I see, thanks Eddie, I seen those white pieces you talked about.
In regards to the Nyloc bolts, is that a brand name or just a specific type of bolt? Also, so i get the nyloc bolts and wing nuts for all of the screws or just for screws for the removal of the drip tray when hot? |
