#813 |
![]() Drives: 2014 LS Join Date: Apr 2014
So what happens if you do this and don't add the rain tray? Will the water that gets inside mess up the engine or something?
#814 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Engine will get wet is all. I'm sure something could get messed up by water getting in but I think it's highly unlikely. I'd put the tray on though, no need to have that kind of risk with a DD. Garage queen? Screw the tray lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#815 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Can someone measure from the hood to the lowest point of the extractor not including the drain pan? Thanks.
The Bird is the word! |
#816 |
I'm trying to do this mod. Can anyone give me the length for A and B in inches? I want to match the same location of the scoop as in the SS camaro.
Thank you
#817 |
![]() Drives: 2017 2LT/RS & 2013 2LT/RS vert Join Date: May 2014
measurement
This is the insert, NOT the hole.
#818 |
Those are not the measurements I used but damn near any measurements will work as long as you center the extractor on you hood. Actually to put it back a little further than I did is better to me cause it keeps you from having to cut into the front support of the hood like I did. I was going off of the Stock locations for the 2014s.
I'm glad people are still doing this mod, its awesome. |
#819 | |
#820 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Hey does anyone know if the water tray leaves enough space between the 1le strut bar or not?
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
#821 |
Don't have a 1LE but but my 13/RS vert has room.
#822 |
Yeah I checked and I would have room if it wasn't for the vararam intake. So I'm gonna have to cut some of the water tray to fit it under the hood
#823 |
Did the install according to jerry7297 instructions, used the 16 3/8 from back of the cowl , really liked the way it turned out! Needed a few beers to start cutting lol Thanks for the write up!
2012 2ss , long tube headers , summit x pipe ,borla mufflers, vararam intake, vmax ported throttle body rdp motorsports dynosteve tuned, BMR trailing arms and bushings elite engineering catch can. [Ifirst camaro ]2012 LT LFX, nytrex wet system ,GPI dyno tune, Injen longtube intake, Dynomax axle back exhaust, Vmax ported throttle body, elite engineering catch can.
#824 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
![]() After a year still liking mine Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#825 |
Anyone want to buy mine?
I bought one intending to put it on the hood of my Colorado, after getting it and doing some measurments i feel the clearance would be too close to the top of the motor.
So I am offering the extractor with mounting nuts and washers for $100 plus shipping. If you are within 100 miles of Johnson City Tn I would be willing to deliver it for just the $100. Message me if you are interested.
The Bird is the word! Last edited by Angrybird 12; 04-15-2018 at 02:09 PM. |
#826 |
![]() Drives: 2010 Camaro SS Join Date: Jun 2014
Z-28 Hood insert
Are some of these inserts wider at the rear than the front? It looks that way in some of the pictures. Maybe aftermarket?
