#1877 |
'It's an experiment'
Photos from Eagles Canyon:
![]() Forest and me parked together: ![]() More action shots: ![]() ![]() ![]() ![]() Nice photos from the day! -Don
747 RWHP 794 RWTQ
#1878 |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Nice photos. Car's looking great!
What group do you run with at Eagles Canyon? Will you be at Cresson next weekend?
#1879 |
Thanks!
Green since I'm new to the track. I thought about it, but decided to do Eagles next month -- closer to home... -Don
747 RWHP 794 RWTQ
#1880 | |
Comparing the 3r vs Toyos:
Goodyear’s 3Rs (ZL1 1LE) https://www.tirerack.com/tires/tires...num=03YR9F1S3R Toyo R888R: Very similar except load rating, price, and sizes: https://www.tirerack.com/tires/tires...um=035YR0R888R https://www.tirerack.com/tires/tires...um=835YR0R888R A nice review: -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 03-16-2018 at 11:23 PM. |
#1881 |
Geoff
My bad 🤗
I meant, track guys / chin / PCA........
#1882 |
It’s open track day and the track puts it on every month!
Very well done and they provide breakfast, lunch, and drinks throughout the day. Fantastic place... -Don
747 RWHP 794 RWTQ
#1883 |
Geoff
You’ve convinced me! I’ll have to give it a go
#1884 |
Great price, 4 sessions, new owners are fixing up the place, FOOD, free track photos! ;o)
If we’re lucky maybe steaks (cows roam out there)... What’s not to like ;o) -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 03-20-2018 at 02:54 PM. |
#1885 |
Apex Pro Track Coach
Well, my Apex Pro finally came in! Installation is a breeze and I ordered the Windshield mount in case I need to move it.
Here it is un-boxed: ![]() Here it is 'charging': Hard to see here: ![]() No flash: ![]() The one thing I'd like to see is the red-led on the back, above the USB wire, or some place easier to see. Small nit but that way I'd know its charging. FYI, this unit uses the USB-C cable -- so if you want a longer USB cable, remember that... Like the magnetic base -- 2 pins -- that are very strong. Looks like a very strong unit! I have a location and I'll put this right in my 'scan' so it will be easy to view. I have the windshield mount if its in the way or, I want to 'let' Danny try it when I get to NCM ;o) Outside of that, can't wait to try it out next month! I'll have 2 camera's going -- GoPro for the track, SJCAM for watching me and the Apex Pro -- should be fun! -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 03-18-2018 at 01:09 PM. |
#1886 |
Took off the belly pan and notice a bit of oil around. Turns out the oil cooler lines near the sandwich needed to be tighten up again -- not unusual since Mishimoto says to check after 500 to 1000 miles after install -- this has 2000 since the last check so I made sure to tighten up the hoses. I'll make that a habit after every race and oil change. It looks worse than it is, very little oil leaked (the dipstick still shows full). Here is what I noticed:
![]() ![]() You'll notice the inspection cover -- I took it off just to make 100% sure its not a rear main -- it was not -- no oil inside believe it or not -- it was all located around the inspection cover. I also noticed my power steering fluid escaped -- turns out its was above 'hot' so had to remove fluid -- did it while it was 'cold' to make 100% sure. Also, because I remove the belly pan so often, I had to add metal washers on both sides of the pan to ensure the bolts don't go through -- working that now... I usually take a week or so after tracking to check things out -- just to make sure... -Don
747 RWHP 794 RWTQ
#1887 |
Buttoned things up and took for a test drive...looks like that took care of it...I’ll watch it over the next couple of days to make sure...
New GoPro Hero to test and I’ll install the Apex Pro next... -Don
747 RWHP 794 RWTQ
#1888 | |
Apex Pro Track Coach (cont.)
OK, mounted up the Apex Pro and followed this guide for calibration (I also calibrated it with me in the car and door shut just to be certain ;o):
Found a great location in my 'scan' and is not covered up by the steering wheel: ![]() Here, the blue light tells me I'm hooked up and ready to go: ![]() Once calibrated, I can remove the unit and not have to re-calibrate as long as I keep the mount in the same location... -Don
747 RWHP 794 RWTQ
#1889 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 2SS Hot Wheels Edition Join Date: May 2013
track day looks like a lot of fun! how did the tires hold up? to your liking or were you disappointed in them?
#1890 | |
-Don
747 RWHP 794 RWTQ
