Old 03-10-2015, 07:43 AM   #99
Camarotobeornottobe
Drives: 1LE
Reference the hood closed vs. open argument, I think everyone needs to keep in mind the reason for the dyno here: We want to know the increase in HP over the stock intake.
So, keeping the hood closed will ensure each has the SAME airflow, i.e. that the air comes from whatever it can suck from the lower inlet. Underhood temps should be the same, so each is at the same advantage/disadvantage.
If you run both open hood, the Z28 is going to have an unrealistic advantage because it is going to suck from the top . . . something it can't do in real life when running the car on the street. The stock intake would not get an air inflow increase since it is closed on the top.
If we cared about doing a Z28 vs. Rotofab, then you could leave hood open for both since both would be drawing from the top.
Camarotobeornottobe is offline   Reply With Quote
Old 03-10-2015, 08:09 AM   #100
Camarotobeornottobe
Drives: 1LE
For those who have the Z28 intake, how confident are you that it seals 100% against the SS hood and hoodliner?
Old 03-10-2015, 08:35 AM   #101
CreeperRS
CreeperRS's Avatar
Drives: 20’ Chevrolet Camaro 2SS 1LE
I agree! We want to know the increase in HP over the stock intake. That is the point. In this case it makes sense to keep the hood closed for a real comparison over stock.
CreeperRS is offline   Reply With Quote
Old 03-10-2015, 09:07 AM   #102
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Originally Posted by Dropspeed View Post
The reason cars are dynoed with the hood open is that there are no public dyno facilities that can duplicate the airflow of a car at speed. Sticking 5 foot fans or multiple small fans around the car does not replicate the airflow the car will see in the real world. They also do not have variable speeds. IE when the car is at 20mph on the dyno it receives the same air from the fan as when it is at 100mph on the dyno. With that said, the hood should be open as underhood temps are not realistic with the hood closed.
hood closed or you will will never be able to compare with the oem air box.
First baseline test with oem hood close, second test Baseline with new CAi hood close.
Having fans or not will only get lower Hp/TQ numbers but the difference in % of gains or loss with be the same.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 03-10-2015, 02:19 PM   #103
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
100% confident. I wet the seal on the Z/28 CAI and closed my hood, then reopened to see the reference mark. It completely transferred the water onto the hood liner.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 03-10-2015, 03:38 PM   #104
Camarotobeornottobe
Drives: 1LE
Thanks. Had there been any question, I was thinking that it would be easy to install a piece of clear plexiglass across the top, using the ridges just inside and below the rim. Would create an effect similiar to the CAI. Might look pretty darn cool . . .
Old 03-10-2015, 04:44 PM   #105
CreeperRS
CreeperRS's Avatar
Thanks for the info.
Old 03-10-2015, 09:14 PM   #106
jim's2ssrs
jim's2ssrs's Avatar
Drives: 2011 2SS RS LS3 Rally Yellow
Do you plan on recording and reporting AFR and fuel trims for the stock intake and the Z28 intake?
jim's2ssrs is offline   Reply With Quote
Old 03-10-2015, 10:14 PM   #107
CreeperRS
CreeperRS's Avatar
I was not aware I could see fuel trims, sounds interesting. How can I do it?
Old 03-11-2015, 07:29 AM   #108
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Fuel trims can be scanned and logged using any of the full tuning packages like HP Tuners or EFI Live. I would think the Dyno shop you are taking the car to would have a scanner that could log fuel trims.
An important note though since your dyno run will likely be done at full throttle the ECM will ignore fuel trims anyhow so I'm not sure what good it does to log fuel trims at WOT. At WOT the car goes into open loop anyhow with fuel enrichment. The wideband O2 sensor would be the most valuable tool for monitoring any fueling affects the new intake has on the engine.
For AFR you would need to use the wideband O2 sensor that the dyno shop should also have available if they do any tuning at all.
Nick S is offline   Reply With Quote
Old 03-11-2015, 07:43 PM   #109
Mgizzle
Mgizzle's Avatar
Drives: 2013 Camaro 1LE 1SS
Dang, didnt think about this I removed my hood liner.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
Mgizzle is offline   Reply With Quote
Old 03-11-2015, 07:55 PM   #110
CreeperRS
CreeperRS's Avatar
Will check with them the day of. They should, they tune cars all the time. After all it is JBA.
Old 03-11-2015, 07:56 PM   #111
CreeperRS
CreeperRS's Avatar
DOH!
Old 03-11-2015, 09:39 PM   #112
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
been reading through this thread and I have this intake setting in my garage and plan on installing it tomorrow afternoon. since I don't have the Oil separator on my L99 then I don't need any extra parts like the 1LE folks right? no need to buy anything extra?
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
