Old 10-05-2021, 10:55 AM   #127
SFR7771
Drag and Drive is Life
SFR7771's Avatar
Drives: 2010 Camaro 2SS RS A6 LS3 Whipple
Thanks
My build link... https://www.camaro5.com/forums/showt...4#post11077544
2010 2SS/RS/ Mods, Whipple, 1000cc injector, 102MM TB, Innovation West 10% OD pulley set up 8 rib, AGP twin 450 fuel system w flex on E85, CAI K&N, LT with OR Cats aka no catalytic converters, Coils and wires, 3" exhaust with mufflers, Oil catch can, 2015 ZL1 9.9 3.23 ratio, BMR upper Lower control arms, 15"conversion, BMR Anti Roll Bar 315/60/15 ET street slicks
1972 El Camino SS 565BBC 950HP, All TRZ suspension
SFR7771 is offline   Reply With Quote
Old 10-10-2021, 11:47 AM   #128
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Well, it has a been a while since my last update. The car currently has ~80K miles on it, and it has had the Whipple on it since ~12K miles. I'm still on the stock clutch.....
Recent upgrades:
- Innovators West 10% OD damper
- Innovators West 10-rib drive conversion
- Grip-Tec 3.25" 10-rib pulley
It has not been to the dyno with the new additions, but it definitely picked up some more oomph!
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 10-11-2021, 04:21 AM   #129
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I was wondering what block you are using? Sorry I've read your entire thread and don't remember and don't won't to re-read the whole thing again. lol
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 10-11-2021, 10:20 AM   #130
Batmanntexas
Stock block and stock rotating assembly. I'm going to build a 416, but will still use the stock block I think. I'm on the fence about that though, as I have an iron Gen III 6.0L block sitting in the garage as well.
COTW 9/8/14
Old 10-11-2021, 10:29 AM   #131
morepowerjoe
That's awesome to hear.
Old 11-09-2021, 08:36 AM   #132
SFR7771
SFR7771's Avatar
OD set up
How much PSI are you now with the 10% OD and did you do UD alternator?
Thanks
Recent upgrades:
-Scott
Old 11-09-2021, 03:10 PM   #133
Batmanntexas
Thanks
I'll have to look a the logs and confirm, but napkin math said I should be close to 16psi. As far as the alternator, I'm still running the stock pulley size.
COTW 9/8/14
Old 11-24-2021, 10:40 AM   #134
SFR7771
SFR7771's Avatar
cam
Scott what RPM did the TSP cam stop pulling at on the dyno for the 804 RWH? Thanks
And Have a Happy Thanksgiving
Got the install done of all parts (fuel pumps, flex fuel, injectors, trunnion upgrade, and camshaft) a little later than I wanted, first week of August. Here are a few pics that I managed to capture.
Old 11-24-2021, 03:19 PM   #135
Batmanntexas
We let off around 6500rpm or so, and the HP was still climbing.
COTW 9/8/14
Old 01-11-2023, 09:50 AM   #136
SFR7771
SFR7771's Avatar
Just curios what your set up is right now? I'm about to tear mine down and start the build. With my T400 conversion also.
Injectors
Pulley
Boost
Any other changes and how does she feel HP wise?
